car will not fire
car will not fire
I 95 honda dx with a 97 civic vtec motor. I have changed ecu, ignition coil, and icm and I still get no spark. Could I have a bad distributor
Re: car will not fire
I checked for spark with the screw driver in the spark plugs. I got no spark from none of them. I have not checked the relay yet
one ting that i would check because i had a d15b7 in my 94 hatch to a d16y8 out of a 96 ex hd no spark had no fuel pressure. the pump wasnt kicking in. what was causing that was bad piggy backs used a z6 intake/tb/inj allong with a z6 harness car fired right off
simple way to see i yor getting fuel is to loosen the bango bolt on te fuel filter unde the hood and see if fuel comes out when yo put the key to the run position (make sure the clutch is in not sure if it matters but better safe then sorry) that is if u dont have a guage
I was giving a p28 ecu. Sometimes the check engine light clicks while cranking sometimes it don't come on, but i did not check the codes. I haven't been home in a few days to check for fuel pressure. But would that really affect the spark.
Rather than measuring fuel pressure, start by telling us whether the fuel pump primes for 2 seconds when the key is turned from off to ON(II).
Next check whether the Blk/Yel wire attached to the coil inside the distributor has battery voltage with key in ON(II).
hcontreras
12-27-2015 02:29 PM
civic702
14
01-15-2005 05:11 PM
