Issue with b series t bracket
Old 06-07-2012, 12:07 PM
topshotta's Avatar
Default Issue with b series t bracket
1995 civic eg coupe
ls motor
ls tranny
The t-bracket that i'm using is not quite fiting. Is there a special b seires t-bracket that i need to use. Please let me know asap. Thank you
Old 06-07-2012, 12:10 PM
kyden's Avatar
Default Re: Issue with b series t bracket
94-01 integra 5 spd. (if using hydraulic transmission)
Old 06-07-2012, 12:24 PM
topshotta's Avatar
ok would the auto 94-01 integra t-bracket work ?
Old 06-07-2012, 12:27 PM
Vagitarian's Avatar
nope
Old 06-07-2012, 12:28 PM
topshotta's Avatar
would a 99-00 civic si t-bracket work too?
Old 06-07-2012, 12:34 PM
mouab18c1's Avatar
You need a manual bracket the 99-00 civic SI bracket should work as well
Old 06-07-2012, 12:35 PM
kyden's Avatar
99-00 si bracket will not work.
Old 06-07-2012, 02:26 PM
topshotta's Avatar
Ok. Confused. 99-00 civic si t-bracket work or not? How do u know a automatic t-bracket from a stick shift t-bracket?
Old 06-07-2012, 04:19 PM
mouab18c1's Avatar
Whys that?
Old 06-08-2012, 03:59 AM
lsturbohatch10's Avatar
96-00 Civics use a different subframe than the 92-95 civics and 94-01 integras. if your are doing a b swap in a 92-95. you need an integra rear t bracket. if you are doing a b swap in a 96-00 civic then you need the SI t bracket.
Old 06-08-2012, 06:04 AM
kyden's Avatar
Old 06-08-2012, 12:39 PM
topshotta's Avatar
ok cool. So i beliver that i have a 99-00 si T-bracket. Thank you
Old 06-09-2012, 02:59 PM
yungkhmer's Avatar
OBD1 GSR REAR T BRACKET.
Old 05-31-2018, 01:19 AM
hatch22ajdm's Avatar
ok what about 00 integra to b16 swap what T bracket would you need?
thanks in advance
Old 05-31-2018, 07:22 PM
egsleepercivic's Avatar
manual integra bracket 94-01
Old 05-31-2018, 07:34 PM
Feriohhh's Avatar
For an EG manual civic swap this. /thread.
Old 06-01-2018, 09:08 AM
Freedo_Civegra's Avatar
94-2001 Integra manual transmission T bracket
Old 06-01-2018, 10:21 AM
Fish Twig
tony_2018's Avatar
There is a difference between the b-series automatic t-bracket and the manual t-bracket, regardless of eg or dc.
blackccoupe
03-11-2014 08:11 AM
semij20
12-30-2005 07:50 PM
ArinX
01-30-2005 06:53 PM
I_LuvmyHonda
09-24-2004 01:55 AM
Quick Reply: Issue with b series t bracket
