93 Del Sol - intermittant crank no start
Old 06-15-2012, 02:07 PM
JeffC's Avatar
Default 93 Del Sol - intermittant crank no start
I first want to say I love this board. I am a 30 year Ford Service Manager. (dont run me off I am also a Master Ford Tech)........... I am though new to Honda and my GF has a 1993 Del Sol with a problem.
Car has been intermittant crank no start. Got info and schematics from this site and chased down my issue. Im looking for backup or anything I may have overlooked before I change the fuel pump.
Started checking fuses31,24 and 18 all good. Pulled main relay, checked connector powers and grounds all good. Bench checked relay good. Check engine light proves out by key, with relay click as it should. Noticed dont always hear pump run when turn key forward. When you hear pump (maybe 1 in 10 key cycles), car will start.
I bypassed main relay, pins 1,7,3. As I read schematic this gives me direct power from battery to ECU/injectors and fuel pump. With relay bypassed has same issue, when you hear pump it starts. Yellow wire which is now direct shows me its the main pump power.
I am assuming that with the main relay bypassed I am supplying direct power to the pump but the pump is not always energizing.?
Please Honda masters help me before I crawl around this little bitty car and remove the console and rear panels.
Any thing I have overlooked or is my theory in the park?
Old 06-15-2012, 02:08 PM
Retired Moderator
EsotericImage's Avatar
Default Re: Need Help!
try the fuel relay
Old 06-15-2012, 02:17 PM
JeffC's Avatar
Where i
s the fuel relay? Thought it was in the main relay... see thats why I asked!
Old 06-15-2012, 02:19 PM
The Grumpiest
grumblemarc's Avatar
Same thing. Not sure where they are in the Del Sols.
Edit. Found pic. Hope it helps.
Old 06-15-2012, 02:21 PM
Retired Moderator
Id say with a 20 year old car, Id replace the pump just on common principle.
Old 06-15-2012, 02:25 PM
JeffC's Avatar
I have removed that "main" relay and checked it. All solder looks good and it bench tests good.
Was just thinking I could use test light after relay on yellow to pump, cycle key and make sure I show power on that wire. If it powers and pump doesnt energize that eliminates relay for sure. (as long as it has 12v)......
Same as removing interior and checking power directly at pump connector?
Old 06-15-2012, 02:27 PM
Retired Moderator
did it look like this?
http://www.ebay.com/itm/Fuel-Pump-Ma...ht_3109wt_1344
Old 06-15-2012, 02:28 PM
The Grumpiest
I've read where people test them out and the soldering points were still broken. They usually re-soldered them and got them working again.
Old 06-15-2012, 02:32 PM
JeffC's Avatar
yes
Old 06-15-2012, 04:44 PM
Former User's Avatar
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Resolder the main relay, clean and tighten the G101 ground on the thermostat housing, and then go from there.
In general, if the problem persists after doing these things, then try swapping in a known good ECU.
Old 06-16-2012, 07:00 AM
delsolintegra's Avatar
Default Re: 93 Del Sol - intermittant crank no start
My experience with 4 del sols and replacing fuel pumps, main relays, fuel pump relays, ignition switches, starters, cleaning grounds, etc.
My problem was a intermittently failing ECU. Moisture/condensation issue.
Borrow a known good ECU and swap yours with a car that has no issues.
This will tell you if it's the ECU.
Old 06-16-2012, 08:56 AM
DaBEast's Avatar
Loose starter wires on starter
David93DelSol
15
11-07-2017 11:59 AM
philztheone
40
04-27-2015 06:57 AM
belairbrian
20
01-16-2015 10:11 AM
Time Ranger
11
08-04-2014 03:07 AM
Kendawg386
07-25-2008 06:16 PM
Quick Reply: 93 Del Sol - intermittant crank no start
