D15 block and D16 head - what head gasket?
Old 06-15-2012, 12:08 PM
chandlerM13's Avatar
Default D15 block and D16 head - what head gasket?
i have a D15B block in my honda and i believe the head is a b16? possibly a D16? i really dont know but the shop i took it too said that it was.
so my question is, when a put the head gasket on do i go with the block? or head?
the place i went too put the 1.6 valvue seals in the head and used the head gasket from that kit and i blew my head gasket.. so thats obviously not right.
so another question, should a change all the seals they put on the block? or will they be fine as the 1.6 seal kit?
i dont know much.. so please help me
Old 06-15-2012, 12:09 PM
EK9
Dc4LsTeG's Avatar
Default Re: motor questions
Post a pic of your motor
Old 06-15-2012, 01:58 PM
Default Re: D15 block and B16 or D16 head - what head gasket?
Old 06-15-2012, 02:05 PM
The Grumpiest
grumblemarc's Avatar
D16.
Old 06-15-2012, 02:10 PM
but with the D15 block.....
i should use a head gasket that matches the block?
Old 06-15-2012, 02:22 PM
The Grumpiest
I was thinking it was a JDM D15B . I think they're all the same. I'll have to do some searching. The stamp on the engine says D15B?
Blowing the headgasket may not be the gaskets fault. Is the head warped? Was there overheating int eh past?
Old 06-15-2012, 02:35 PM
yes the stamp is D15B
and i had a cracked valvue.... got the head re done and everything.... put it back together with the head gasket kit they used for the head and the next day... head gasket blew. i believe... under the valvue cover was water, anti-freeze and water...... im taking it apart and looking now
and it didnt overheat untill it blew white smoke and steam AFTER i got the head redone
Old 06-15-2012, 02:42 PM
The Grumpiest
I'm going to say to go with the OEM D16 head gasket unless someone that knows for sure says otherwise.
EK9
Dc4LsTeG's Avatar
Whats the code on the front of the head above the header
Old 06-15-2012, 02:44 PM
Civic2Fast's Avatar
right on grumble... the d16 gasket is what needs to be used
Old 06-15-2012, 03:04 PM
i see....... P08-2
and 9757?
Old 06-15-2012, 03:06 PM
The Grumpiest
https://honda-tech.com/forums/tech-misc-15/d-series-head-codes-786093/
92 Si D16Z6 5sp------- P08-2 (9/2) stamped on RS of code.
94 EX D16z6 5 spd---- PO8-2
Old 06-15-2012, 03:08 PM
its actually 91757? i think
Old 06-15-2012, 03:10 PM
D15B (JDM)
92 VTi D15B Auto--- -- P08-1 (9/1)<-- RS of Code
thats it...
Old 06-15-2012, 03:11 PM
so now with taking off the timing belt...
how do you mark it?
Old 06-15-2012, 03:14 PM
scratch that... its not the "D15B (JDM)
92 VTi D15B Auto--- -- P08-1 (9/1)<-- RS of Code"
its p08-2
Old 06-15-2012, 03:15 PM
and my car is an automatic... so hows that work?
Old 06-15-2012, 04:17 PM
The Grumpiest
How's what work?
Old 06-15-2012, 05:47 PM
nevermind... we got it all apart and found the problem....
whoever did the head work didnt get new head bolts........... f#ckers.
Old 06-15-2012, 06:23 PM
EK9
Dc4LsTeG's Avatar
Make sure you still replace the head gasket
Old 06-15-2012, 07:15 PM
yepp. got all new gasketss....
since i have everything taken apart is there anything else worth changing? or fixing that could be broke?
or any cheap aftermarket parts that would make my car better?
Old 06-15-2012, 07:26 PM
RussLaviolette's Avatar
I wouldn't buy aftermarket head bolts. They are a must every time a head is lifted. Some will say they can be reused once, but my experience has taught me that it's best to buy OEM Honda bolts any time you pull the head. If you haven't already changed the water pump, and timing belt I would. Also, make sure the timing belt tensioner is operating smoothly. It has bearings within it so make sure they don't sounds like they're metal-on-metal or there's resistance. Not a bad time to change the front main seal either.
Hope you figure it all out!
Old 06-15-2012, 10:40 PM
jbpnoman's Avatar
You should never put cheap parts in your motor, unless you fancy the idea of replacing them within a year. They're cheap for a reason.
While you're doing the head gasket, you'll want to to intake and exhaust manifold gaskets, valve cover and spark plug gaskets, timing belt, water pump, and timing belt tensioner. It also wouldn't hurt to have your injectors cleaned while you have everything apart.
Old 06-16-2012, 10:07 AM
so, ive called places all around my area and no one has head bolts.... whats the next best place to look online for them?
thanks for the help everyone
Old 06-16-2012, 10:24 AM
The Grumpiest
Ebay.
MigsD16
Engine Machining & Assembly
12-17-2016 05:17 PM
JDMpadawan
03-18-2014 12:27 PM
chandlerM13
Engine Management and Tuning
06-15-2012 12:06 PM
strike1545
05-24-2010 10:42 AM
1BADEGDC2
10-23-2008 05:04 PM
Quick Reply: D15 block and D16 head - what head gasket?
