Stereo Issues.
Stereo Issues.
hey everyone. i have a 1996 honda civic that im attempting to hook up a pioneer head unit to, i connected all the wires and it seems that on the plug that connects into the factory harness has one additional wire (orange and white stripped) and its called "positive dimmer" for some reason, my head unit has NO POWER, no lights, no NOTHING...
if anyone could help me out id appriciate it!
Re: Stereo Issues.
you should have 3 wires that control your power
Yellow
Red
Black
Black is ground obviously.
Yellow is the constant B+
and Red is a switched B+ when the key is in accessory or run position.
what model civic do you have? you should check your wiring, the fuse on the back of the deck, and then the fuse in your fuse panel.
Re: Stereo Issues.
Brand new deck, just bought it tonight from best buy..... will test it tomorrow a test light, i dont have one at home right now :/
The Grumpiest
Re: Stereo Issues.
Are you using a proper wiring harness to do the install or are you cutting and splicing? There should be no issues if you're using a proper harness. You should also NOT be splicing ANY wires into the dimmer switch/circuit.
elmalouno
Audio / Security / Video
12-07-2004 01:36 PM
wickedxbo1
09-21-2001 08:35 PM
