need help y8 with 3 stage vtec head in 99 ex
i found a 3 stage vtec head for sell and i wanna get it and put it on my 99 ex/y8 bottom end ive never done one and always wanted to.i jus wanted to know if i could just buy it and throw it on the bottom end and use my stock ecu i was gonna install the head to the y8 bottom end and just take the one wire vtec plug from the engine harness and splice it into the twin vtec soleniods.WILL THIS WORK OR WILL MY CAR RUN LIKE **** WHAT WILL I NEED TO MAKE THIS WORK PLEASE HELP ME THANKS DEAN
Re: need help y8 with 3 stage vtec head in 99 ex
If you use your vtec solenoid, intake manifold and plug the pin holes on the intake side of the head it'll work with your ecu
unlike an HX that goes from 12 valve with swirl, to a normal 16 valve low cam.
The Grumpiest
Which he doesn't have. There's a guy that's been trying to get this to work for months without the proper ECU and still hasn't gotten it working properly.
http://www.ebay.com/itm/JDM-96-98-Ci...sories&vxp=mtr
Here's an auto ECU for half that. Don't know if you can convert it to manual.
http://www.ebay.com/itm/1997-Honda-C...#ht_500wt_1180
If you get it working you get the best of both worlds.
I know what the motor does Ive been working on Hondas since you were 9. Hes got an EX not an HX. Difference of opinion. Id find a way to get power out of it otherwise leave it alone
power and economy is better than power alone. why use a 3 stage head for power? for the money of the head, and ecu you could keep the y8 head and spend it on a cam, and springs, and intake manifold.
The Grumpiest
^^You're assuming the OP is aware of what function a 3-stage VTEC actually plays in a Honda. I've found that most people have no clue or have the totally WRONG concept floating around in their heads. Kinda along the lines of "If a single VTEC is good, then 3-stage VTEC is even better".
JAYSCRX420
07-14-2018 11:39 AM
vital123
10
12-16-2009 12:56 PM
