Mechanic says switch to 10-40 semi synthetic - Should i trust him?
he told me i should switch to semi synthetic and 10-40 since i have allot of miles what do you guys think?
Re: should i trust my mechanic
i switched to 10w40 full synthetic. it makes sense. high mileage engines have bearing wear, and a thicker oil will allow the oil to stay inside those bearings without spilling out thus (losing pressure and flow to the top of the engine)
Are you burning oil?
I would say high mileage oil is fine, semi sythenthic some are, but regular high mileage oil is fine, 10w 40 is good if you are burning, if not 5w 30 is fine.
yup thicker oil in the summer, and thinner in the winter. thats what my daddy told me years ago haha and i still remember it, even if i dont exactly do it :p
My dad has used high mileage since I would say around 06ish. And there has not been any issues...but every Honda is different. It all depends on how the car is taken care of and maintained.
Go to www.bobistheoilguy.com The short answer is stick with 5w30 regular or synthetic. Penzoil is the best for the $.
Re: Mechanic says switch to 10-40 semi synthetic - Should i trust him?
Use this **** and change it every 3-5000 miles, whenever you feel like it. Cheapest oil filter every other change.
Walmart...
Oh, and my 17 year old D16Z6 DOES NOT burn any oil, regardless of which I use. 3.5 quarts in > 3.5 quarts out...
If the engine is not smoking ,ticking ,leaking , or burning oil then it is best to stick with the factory spec oil for the stock d16z6 5/30 if it starts drinking it then switch to somthing thicker as for the Walmart oil I haven't researched it but I personally wouldn't put that in my lawn mower you don't have to buy the high dollar stuff for a civic it's not a ferarri but stick to a decent quality oil and filter for piece of mind if nothing eltse not to say that the Walmart stuff is crap oil it may be a re brand of some other stuff like Canadian tires formula 1 synthetic which I found out to be a shell or esso synthetic rebrand if you find the material safety data sheet it should have a company logo and product information on there.
I have SOME experiance on the matter I have performed minimum 250,000 oil services
On all types of vehicles and I own a si with d16z6 and a dx hatch with a swapped jdm d16zc vtec which is almost identical to the d16z6 any other questions I would be more then happy to help out
If you loved me, you'd all sell me your magic cards to me today
