1992 honda civic antenna help
When I got my car, it had no antenna so I dont know where the antenna hole under the dash is. When I try inserting the antenna wire down the driver pillar from the roof, I dont know where it comes out. Does someone know where it comes out? I've been trying to look for it.
The Grumpiest
Re: 1992 honda civic antenna help
Where else would it come out of? Like I said n the thread you bumped, it routes down the A-pillar then under the dash. There is only one hole and that's on the roof.
O.G. triple O.G.
^^ You don't have to remove the kick panel. The cavity ends at the height of the PGMFI relay. Use a "fish tape" or metal coathanger to pull the new antenna cable through.
Yes I am aware there is a hole on the roof because thats where im inserting the antenna from. I just need to know where it comes out under the dash. Be specific as to where it is because "under the dash" isn't helpful.
The Grumpiest
Where and what is what?
Dude. Get the new Antenna. Fish some wire down into the hole until it comes out the bottom of the A-pillar on the INSIDE of the car. Attach the wire, however you want, to the end of the new antenna and pull it through.
What is so hard about that?
305_DB7ish
03-25-2015 12:52 AM
Zing
08-07-2004 03:25 PM
