Hid conversion help....
Well i did do a search but couldnt find anything.
Okay on with the question. My friend is selling me his HID kit, but its an H1 kit. And i wanted to use it on my projectors which are H3. How hard is it to make the H1 Hid kit fit in my projectors?? if its too hard, ill just forget about it.
Re: Hid conversion help.... (SjCiViCHB)
I heard the beam pattern is horrible if you use projectors. Can anyone else confirm this?
I had a Civic with projectors and HIDs behind me once and I can tell you the colors were bouncing all over the place. Not sure how much relevance that has.
Re: Hid conversion help.... (Underage hybridreams)
Re: Hid conversion help.... (euclid)
im waitin for mtk to reply. I think he can pretty much answer my question. From readin the other threads i found when usin the search button it looks like he knows alot about HID's.
dont have any help for ya with out looking at it but my buddy has a hid kit on his sc300 and it has projectors and it looks phat as hell
Re: Hid conversion help.... (showspeed.com)
well the main question i want answered is if it would be hard to make H1 Hid's fit in my Projectors which use H3 bulbs. I wanna know if it would be a hard modification or an easy one.
just buy a set of h3 bulbs.....
who makes the kit?
most companies make kits for h3 bulbs.......
if you look closely at h3 bulbs and h1 bulbs they are very similar. so It shouldn't be too hard to modify the base to make it fit. however.....h3 bulbs are much shorter than h1 bulbs to they h1 bulb might be to long to fit in the projector.
IMO, I would just get a set of d2s or d2r (whichever they are) for your kit and be done with it.
who makes the kit?
if I were you, I'd get a set of Audi or BMW HID projectors (along w/D2S bulbs and ballasts), and then retrofit them into your current projector headlights. This link should give you an idea... http://home.earthlink.net/~pliepl/_wsn/page2.html
Trust me, you'll be happier later if you done this.
btw, how much is your friend selling the kit?
Re: Hid conversion help.... (DIESEL8118)
hes sellin the kit to me for 350. Hid kit plus ol skoo Nintendo!! yeeeeee....
so what your saying, is i should just get some projectors from an audi or bmw, and just use the projectors with the hid kit??
[Modified by SjCiViCHB, 6:57 AM 1/23/2003]
[Modified by 94hondaLS, 11:05 PM 1/22/2003]
[Modified by 94hondaLS, 11:07 PM 1/22/2003]
great post dude, does anybody know where i can buy a set of used audi s4 headlights complete with balasts and bulbs?
[Modified by euclid, 3:44 AM 1/23/2003]
great post dude, does anybody know where i can buy a set of used audi s4 headlights complete with balasts and bulbs?[Modified by euclid, 3:44 AM 1/23/2003]
You can grab a set of Audi or BMW HID projectors for about $150, then $250-$300 for D2S bulbs and ballasts. Also Check out www.illusion-lighting.com
hth
i found a set of a4 lights on ebay for 425$... when you had yours were they high quality, and what is the intensity, 4300? have you seen the audi lights in person? if so how does the beam look, what color, and how bright?
Most of the stock Audi or BMW xenon headlights use 4000K series bulbs. Yes, I have seen them in person. They're more like bluish light. The beam pattern spreads out evenly, and the cutoff line is excellent. Check out the sites I mentioned above, and you'll see what I'm trying to say.
hth
i think i will order that set i found... i need a set of projector headlights to retro fit them into though, i have a 94 civic and if i use my stock housings the lense will scatter the light everywhere b/c it has grooves in it. thanks for all your help, that site you listed was the most informative ive seen so far on the topic.
hey pal.. you're in luck.. its pretty easy to make H1's fit into an H3 hole.. you just need a couple washers to bring the bulb back and you're in there.. just make sure the bulbs hes got arent D2R type..meaning the glass capsul is fully clear with no black lines on it and u should be fine.. here are some pics.
ok, here is step 1.. put the bulbs side by side with a straight line on a paper, or u can just set them on a ruler.. u notice the distance from the base to the filament & base to gas bubble are not the same length on the bulbs..
step 2.. buy some heat resistant washers to put on the base of the HID bulb to make a new base.. notice how the bubble and the filament match up now, and also the bases do too..
you might also want to put the bulb in, turn it on ONE SIDE ONLY, leave the other side halogen.. then turn the HID bulb inside the hole til you get an exact beam match on the garage or wall.. then secure the bulb somehow.. you might need to take the housings off the car to make a new holding pin because im sure the HID base will be a little too big.. but good luck man.
Re: Hid conversion help.... (MTK Kommander)
Thanks alot MTK....really really helpful. Answered my question with no problems. And thanks to the other guys for that website.
