LS swap in the process
hey h-t , what a great place to hang around.
anyway, this site got me so hooked on fixing my car, and i saw so many nice swap and nice hatches, i got involved in doing it myself.
so happy is in
List of questions
1. LS swap went in, car started without check engine light , right now, I only put the driver side axle in and passanger side hasn't go in yet, when the car started and let it run, everything is ok, but when I rev it up, my MPH goes up and down 0-25mph. So what is that all about?
2. Since the swap, now the (eg)cytalytic converter and the (teg)header where it meets, there's like a 1.5 to 2 inches gap in between and i couldn't bolt them together. Now what can i do? I am going to try to use the one from the integra tomorrow, would that work?
3. Knock sensor, I have read and searched that I need to wire the knock sensor to the teg ecu. How? Red/Blue to D3, that's all i know, i can get more details please.
thanks. More to come
edit: fixed pix
[Modified by intezn, 11:05 PM 1/20/2003]
[Modified by intezn, 11:08 PM 1/20/2003]
so happy is in
List of questions
edit: fixed pix
Solbros Owns Me
Re: LS swap in the process (ace1875)
patience my friend.
Sorry, I cant answer your questions.
Edit
The speedometer could be some wiring or a fuse.
The Teg cat should fix that problem to my understanding/
[Modified by Emerica, 11:09 PM 1/20/2003]
Edit
Re: LS swap in the process (Emerica)
when i had mine done, it took it to a local muffler shop, they just welded in a connection plate. i belive you need both halfshafts.
Re: LS swap in the process (HuskerHybrid)
I like LS.....Nice dent..
[Modified by intezn, 11:29 PM 1/20/2003]
Re: LS swap in the process (intezn)
the teg cat should be 1-2" longer than the civic.......the more cost-effiecient way out would be to just have a muffler shop weld a 2" extension with flanges on both ends to make up for the slack.....i'd say $10-20
[Modified by SpoonFedHatch, 7:30 AM 1/21/2003]
HTH.
PS, If you have anymore questions, feel free to IM me. I did this swap about a year ago and I may be able to help you more.
Re: LS swap in the process (94HybridEX)
I don't know what you're talking about. The only reason you might run into problems is if you aren't using the LS ECU. You have an OBDI motor, so use theOBD I LS ECU (P75) and it should plug in with no problems
yes, i am useing the LS ECU (P75) and i read that and some people tell me the only mod i need to do is add the knock sensor wire. I am using the si wiring harness by the way. Everything clip right in from the motor to the wiring.
Also like someone else said, check all of your connections and make sure your grounds are all good. You should be all set.
Re: LS swap in the process (SpoonFedHatch)
I could be wrong, but I am 99% sure that your LS motor does not have a knock sensor. That swap should be 100% plug and play with your Civic (I have never heard of people having catalytic converter problems before). All your wiring from the Civic should plug up to the LS perfectly (have to extend some wires and there will be a few left over since you said you are using Si harness and Si has VTEC plugs). Your ECU should also plug right in and work perfectly. Your speedo is getting a reading without moving because you don't have the second axle in.
Re: LS swap in the process (b16a ferio)
Re: LS swap in the process (94hondaLS)
knock sensors are only on vtec motor's and the header to cat thing i had too ya its just how it happens i went to a muffler shop and had then put on a gutted cat and pipeing all the way back
Re: LS swap in the process (HybridHackBatch)
i had a flex pipe added to compensate the gap
what year LS....
what year LS....
