Si-R front brakes, same as US GS-R??
Well, I have a 92 VX hatch that came with 4 wheel disc conversion, which I was told had JDM Si-R front brakes and GS-R rear. Now, the rotors are warped in the front and I am looking to get them replaced, but I need to know what rotors I should order. Are JDM Si-R fronts the same as US GS-R? And is there a way to tell what brakes I have for both front and rear? Sorry, kinda uneducated on brakes. Any help is appreciated
Re: Si-R front brakes, same as US GS-R?? (Snoopy1)
CAN Si-R = USDM SI
As far as brake rotors go :
USDM SI = USDM EX = USDM GSR
All use the same front rotors. If in doubt, you can measure the rotor. It should be 10.4". If not, then you have been hoodwinked... bamboozled... etc...
Re: Si-R front brakes, same as US GS-R?? (kommon_sense)
where on the rotor do I measure from? Is 10.4" the diameter? Or just the length from the hub to the outer edge of the rotor, ie the surface of the rotor that the pad contacts?
Ok, I'll check them to see when I get a chance, thanks. Anyone else have knowledge on Si-R brakes? Or whether or not it matters if I buy rotors for a GS-R if they are Si-R, it should be compatible right?
Devil CRX
10-08-2009 09:33 AM
Slo_RSX
12-03-2008 12:14 PM
EGO
13
12-26-2002 01:57 PM
