5 Lug Conversion
5 Lug Conversion
What's the difference between the ITR 5 Lug Conversion and the CTR 5 Lug Conversion? For some reason the CTR conversion seems to be cheaper. Would it be hard to find replacement parts for the CTR conversion because it's not here in North America?
Re: 5 Lug Conversion (joe_bocc)
CTR conversion would be cheaper because the EK LCA's would not be able to be used on a DC or EG chassis, so all you would get are the essentials, the upper LCA's and the discs and calipers, unlike a ITR 5 lug you can get the lower LCA's and the swaybars and other misc stuff that will go on any DC or EG chassis, but the EK chassis kinda limits u. my .02 cents.
the newer jdm itr 5 lugs have bigger axles. ctr are same as itr but i ithink different lca's. either way you can always use your stock if you get an itr swap and if its going on an ek. replacement parts= just use itr.
[Modified by R you serious, 11:52 AM 1/20/2003]
Re: 5 Lug Conversion (R you serious)
Well i want the conversion for an EK chassis so would it be better for me to get the CTR or the ITR conversion?
Re: 5 Lug Conversion (CheezeFrog)
CTR conversion = $1200-1500
ITR conversion = free
what do you mean by <U>free</U> for the ITR conversion?
Re: 5 Lug Conversion (Peagreenhatch)
<U>uses USDM 32mm axles</U>
all USDM ITR 5 lug
all JDM CTR 5 lug
<U>uses JDM 36mm axles</U>
all JDM ITR 5 lug
correct me if i'm wrong
if you want direct bolt on i would say go for the first two choices
[Modified by Kid1320, 12:30 PM 1/20/2003]
all USDM ITR 5 lug
all JDM CTR 5 lug
all JDM ITR 5 lug
Uneekpinoysk8er
11-21-2004 06:54 PM
kent
02-27-2003 06:36 AM
ESCALVANTE
11-27-2001 07:20 AM
