Speakers/Headunit die out randomly, What to do???
alright randomly today my music would cut off and play for a lil bit and then cut out again. right now my headunit turns on and plays tracks but the speakers aren't putting out sound.
i have checked the 15a fuse under the dash and i checked one under the hood, the backup 7.5a i believe, both were fine. i actually replaced the 15a for ***** my speakers are still out.
anyways when i turn on the headunit i hear the speakers for a split second, this little sound comes out right when i turn it on and then nothing else. i checked my grounds and all seem to be fine. any ideas???
Re: Speakers/Headunit die out randomly, What to do??? (eghonda)
If it was only your headunit turning off and on I'd say that it could be an ignition switch problem (Had it on my jetta awhile back...) But since its your speakers, does it only cut in and out when your moving? If so, maybe a connection on the back of your headunit is bad. Other than that, depending on how your system is wired (system being what it should be: All your speakers), it is probably where the wires split to go to their respective speaker.
Re: Speakers/Headunit die out randomly, What to do??? (protzler)
yea it only cuts in and out while moving, but while stopped i get no sound at all
i only have 2 speakers in the front doors...maybe it has something to do with all this rain we've been getting????
check all of your wireing. You may be grounding out a channel or two some where. Just take it all out and see. Also ask the audio/visual people
2007Civic owner
Audio / Security / Video
10-02-2018 03:31 PM
eghonda
04-03-2004 07:48 PM
