Running Vtec...Need Help...
Last week i i crashed my car and i just got my insurance check for it, so now i found a 93 hatch dx, but i want to swap it immediately..Throw a gsr in it or somethin, but the only problem is that i have no idea how to run vtec wires through a car that originally didnt have vtec...is this hard to do? Please help me out alittle bit...
stew
stew
Re: Running Vtec...Need Help... (stew18564)
nope not hard to do at all. search get the ecu pin outs. run the wires vtec/oil pressure switch/ knock sensor through the little hole in the fire wall ( has a rubber groumet in it)right by the battery and it comes out right by the ecu plug them up and you have vtec. takes about 30-45mins depending on how good u are with wiring & splicing
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stew18564 »</TD></TR><TR><TD CLASS="quote">Last week i i crashed my car and i just got my insurance check for it, so now i found a 93 hatch dx, but i want to swap it immediately..Throw a gsr in it or somethin, but the only problem is that i have no idea how to run vtec wires through a car that originally didnt have vtec...is this hard to do? Please help me out alittle bit...
stew</TD></TR></TABLE>
No not hard to do at all. If you goto http://www.hasport.com/Tech/Wring/EGDX-GSR.pdf this will show you all the wiring conversions you will have to make to put a GSR motor in your DX civic. MAKE SURE you use the proper guage wires since most electrical signals for the ECU are very sensative to extra resistance. If need need any other help with this swap let me know. HAPPY TUNING!!!
lol im not all that good at wiring/splicing...but im sure i can figure it out...i just need to get some kids together to help me put this **** in, im new to this honda stuff, but all my friends are all into it so perhaps they will know how to do all of this? hmm...
hondafanatic, do you have aol? i got some things i could ask you...
Modified by stew18564 at 12:02 AM 4/4/2004
Re: (stew18564)
I don't have AOL right now. You can use the Honda-Tech im system. With wiring it is very crutial to take your time. Make sure it is done to perfection the first time. Before anything goes wrong. I had two wires on my MAP sensor switched and it cause my ECU to think I was at full throttle 100% of the time. This caused me to get 9-11mpg with premium gas. OUCH!! it hurt. But thats all fixed now. Just an example. An even worse example is a fried computer. Go ahead man, ask away. I will do my best to help. HAPPY TUNING!!!
Re: (HondaFanatic708)
Vtec is very easy to wire aslong as you got the acutall ECU pins because it's about the only thing that plugs in the harness. You will also have to change the one wire o2 to 4 wire, so it would be better if you have some one around who did this before.
