what the hell are these lines.. Newb quest.
Ok sorry for the newb question. i was reading through HCI and i came across brandon's EK. and i am trying to figure out what the hell are the 2 tubes coming out of the valve cover are for? Have not seen this b4. so a lil help please
The 2 tubes on the front of the valve cover
Re: what the hell are these lines.. Newb quest. (JDMlifestyle)
A few cars have this done that i have seen.
Goes to the Catchcan possibly to releave more crank pressure.
Re: what the hell are these lines.. Newb quest. (boo bees)
wow those are some educated guesses.........
it is to relieve the pressure as 99blackcivicsi has mentioned, some poeple connect them to catch cans or ive heard of poeple connecting them to 1 way valves put on the exhaust piping, so it kinda of sucks out the vapors/pressure
Re: what the hell are these lines.. Newb quest. (B18C_eg)
it is to relieve the pressure as 99blackcivicsi has mentioned, some poeple connect them to catch cans or ive heard of poeple connecting them to 1 way valves put on the exhaust piping, so it kinda of sucks out the vapors/pressure [/QUOTE]
VW guys have been connecting them on their exhaust. they have been doing it for years. Supposedly they gained hp on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_eg »</TD></TR><TR><TD CLASS="quote">wow those are some educated guesses.........
it is to relieve the pressure as 99blackcivicsi has mentioned, some poeple connect them to catch cans or ive heard of poeple connecting them to 1 way valves put on the exhaust piping, so it kinda of sucks out the vapors/pressure </TD></TR></TABLE>
Re: what the hell are these lines.. Newb quest. (AlphaCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaCivic »</TD></TR><TR><TD CLASS="quote">they arent tubes.
they are engine grounding wires. really ******* big ones.</TD></TR></TABLE>
Tell me that you are joking..
Rob
Rob
Re: what the hell are these lines.. Newb quest. (rjardy)
BWAHAAHA overkill engine grounds (plural)! LOL. To the people who said they go to catch cans Exactly what fluid would be coming out of your valve cover? LOL. On another note is that a bootle of wine he's using as a hood prop?
Re: what the hell are these lines.. Newb quest. (SIRIUS)
most people take a line from there pcv to the catch can and one from the intake manifold to the catch can (vacuum) *shrug* With 2 lines from the valve cover, how is this going to suck anything?
haha
haha
1 Post
Re: (Dimi)
sorry if i sound ignorant guys, but msg me up on aim, menkio001 about what purpose these have. I assume its for excess oil float that gets threw around, the presure, i'm not sure. Explain please..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">pcv
Rob</TD></TR></TABLE>
like rob said they are for a pcv valve...my friend who has a b20/vtec has the same setup..its for a pcv valve...
1 Post
Re: what the hell are these lines.. Newb quest. (spunky424)
ok.. so i did a little research,
pvc basicly helps keep the oil cleaner, so unburnt gases gets moved outside the engine element and into fresh air. Recuding presure, less oil toxicfacton. Gonna go check mine out, clean it out. Thanks for the clear up
:edit: sorry i cannot post agian cuase of trail status. But.. it seems like when your running an all motor/high comp build, or a setup that is in serious risk of detenation a catch can/pvc setup is well.. well wotth it.. i think i'll make one this weekend
Modified by DewMota at 3:33 PM 4/3/2004
Re: what the hell are these lines.. Newb quest. (DewMota)
DewMota Now keep reading "The OEM oil seperator box on a B18C1/5 and B16A may not be sufficient under some conditions. Also, some build ups like the LS/VTEC or B20/VTEC may not have an oil seperation setup at all without having to use a custom one. It is important to filter out the oil vapors from the crankcase from the PCV system because the added oil actually lowers your octane rating of the fuel therefore increasing the likelyhood of detonation." C-speedracing
Modified by doublejz at 11:15 AM 4/3/2004
that is not a tru crank case breather,the moroso endyne kit is the real deal,plumbs into the block @ the 2 freeze plug by the crank,that "catch can" is just to let the valve cover breath a little,if you were to pay attention how the valve cover line would go into the intake system,this system just catches remains of oil that would be sucked into the intake,just some added bling bling,like putting a apc small filter on the valve cover...lol
after reading these replies...its almost evident that honda-tech is not the place to get factual information to assist in any way
Re: what the hell are these lines.. Newb quest. (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian »</TD></TR><TR><TD CLASS="quote">after reading these replies...its almost evident that honda-tech is not the place to get factual information to assist in any way </TD></TR></TABLE>
true, this scares me
