Spring Bolts for Apexi N1, help quick
I'm about to put my N1 on my 93 SI Hatch and I have no spring bolts what so ever from the exhaust that is on the car now. Anyone know what size would fit the N1? Thanks a lot.
Re: Spring Bolts for Apexi N1, help quick (JdmEGHatch6)
anyone with an n1 out there that can help, i dont think stock ones fit... at least they didnt on my friends invidia...
I had the A'PEXi N1 on my Civic quite a few years back, and if I remember correctly, I used all stock bolts. If you need the spring bolts, you can get them at your local dealer. I had to buy two after I lost them, and I was charged $30.
EDIT--Now that I think about it, maybe I didn't use the stock bolts for the rear-section. I can't remember. I think I'm getting my A'PEXi N1 confused with my Spoon N1. I had the A'PEXi like four years ago, so my bad memory's even fuzzier.
Re: Spring Bolts for Apexi N1, help quick (Daniel)
the n1 cat back does not use spring bolts...mine didn't, it only used spring bolts where it connected to the header....thats it.....and come to think of it that was the test pipe that used them....every other connection was just regular bolts with nylon colar, and washers...
Re: Spring Bolts for Apexi N1, help quick (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">the n1 cat back does not use spring bolts...mine didn't, it only used spring bolts where it connected to the header....thats it.....and come to think of it that was the test pipe that used them....every other connection was just regular bolts with nylon colar, and washers...</TD></TR></TABLE>
Right-t-o, the only spring bolts should be where your cat or test pipe bolts to the header/down pipe. If that is what you need then I got some from a local parts store for unde $10
The dealership is good for getting quality OEM mechanical parts but whne it comes to nuts and bolts, it makes no sence to spend $30 on two bolts and springs
