195/50-15 on stock Honda wheels
Who here is running this tire size? Do you have a pic I could see? I'm thinking of buying this size for my GS-R wheels because they're MUCH cheaper than 205/50-15 for the AVS ES100's, so I just want to see what they look like. If you're running 195/50 ES100's and have a pic definitely post it up please. I know my car will sit lower but I just want to get an idea of how much.
Re: (jL iLLuZiOnz 9)
No, on Integras the stock size is 195/55-15 (slightly larger sidewall and overall diameter). Right now I'm running 205/50-15 ES100's which are about $72/tire at the Tire Rack, but I'm considering going with 195/50 ES100's which are only $54/tire, so that's a savings of almost $75 for the set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">stay with 205/50/15.</TD></TR></TABLE>
okay, but no one has pics of 195/50-15's on Honda wheels?
i used to have some 214/40/15 dunlopSP9000 on some 96tegSE wheels......those things were nuts a guy gave me $400 for the wheels just cause he wanted the tires...
Re: (xsellxoutx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx »</TD></TR><TR><TD CLASS="quote">i used to have some 214/40/15 dunlopSP9000 on some 96tegSE wheels......those things were nuts a guy gave me $400 for the wheels just cause he wanted the tires...</TD></TR></TABLE>
wurd...but...I ran 215/50/15's before with a 4 in drop, the results were pretty bad...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">you need a pic to see how much wider 205 is compared to 195?</TD></TR></TABLE>
Thanks guys, I wanted to see how the sidewall height compared between 195/50 and 205/50.
Darth ModerVader
Re: (PatrickGSR94)
I'm not sure if this helps you or not, but if the tire is 100% true to its sizing (which is rarely the case), the dimensions would be as follows:
195/50-15 -- 3.84" sidewall and 22.68" overall height
205/50-15 -- 4.04" sidewall and 23.07" overall height
195/55-15 -- 4.22" sidewall and 23.44" overall height (stock size for comparison)
I'm sure you're already aware of this, but the 195/50's (and even the 205/50's, but to a much smaller degree) will slightly affect your speedometer readings and also effectively lower your gearing.
Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
Thanks guys, I wanted to see how the sidewall height compared between 195/50 and 205/50.</TD></TR></TABLE>
U need picture of the back of cars with both tires.
Re: (Blk_Guy_N_S3DAN)
I've ran 205/50 tires before and I now have 195/50 tires. And I don't really feel any difference between the two sizes except that my 195/50 tires seem the grip better. But then again, I have 195/50 S-03s compared to 205/50 Kumho 711s. But here is a size comparison for you. 205/50 on the Enkei's and 195/50 on the Rota's.
BTW, I like the 195/50 better because I'm a weight reduction *****.
