map sensor ???????????
would a bad map sensor cause a high idle my car has been idiling wierd lately no cel's ,but the tonight i had one come on and it was the map and i messed with the wiring and the cel went off and it seems to idle better im just curious if that could throw my idle off.
Re: map sensor ??????????? (ek-guru)
Mine used to throw a map code randomly for no reason, i would clear it and it wouldn't come back for a while.
I think you should look elsewhere for your idle problem, maybe a vacuum leak or low coolant level
Re: map sensor ??????????? (rated_r)
ok so i changed the iac valve on my car i took the one from my old sohc and put it on there and it was running good then i ran it hard for a minute then the cel came on for the iac valve any ideas
Prevail
02-26-2003 05:57 AM
