stock fuel pressure for b16
i have a b16a3 with the following mods:
aem short ram
dc 421 header
B&m fuel pressure regulator
apex ni exhaust with high flow cat
aem cam gears
msd ignition
p28 with jun chip
after putting in my jun p28, my motor has serious idle problems. i adjusted the fuel pressure to 38psi and am running without the vacuum line. it bogs when cold starting and is running rich. also when coming to a stop, it idles irratically and goes down to about 550-600 rpms till i push the gas then does it all over again.
is this the fuel pressure? is this cold start problem for a jun program normal?
what else could it be? fuel pressure too high?
aem short ram
dc 421 header
aem cam gears
msd ignition
p28 with jun chip
Re: stock fuel pressure for b16 (EGB16hatchie)
I have mine @ 48 PSI with the vaccum line on. If it started doing this after you installed the JUN program, I would imagine that's the problem. But IMO 38 is too low. My bad I posted twice.
Re: stock fuel pressure for b16 (EK9DREAMS)
bumping up the fuel pressure to 44psi would only make it run richer. you guys had this problem? what else could i check/do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9DREAMS »</TD></TR><TR><TD CLASS="quote">I believe the stock fuel pressure for the b16 is 44 psi</TD></TR></TABLE>
nop, it's 38psi
nop, it's 38psi
Re: stock fuel pressure for b16 (ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ce »</TD></TR><TR><TD CLASS="quote">
nop, it's 38psi
It is 38. However, you should turn it up. Better to give it more fuel than less. I tried running @ 38 PSI, it just shitted out on me.
nop, it's 38psi
Fuel pressure DROPS to Zero immediatly after Priming (aftermarket sysytem) ALREADY CHECKED FOR LEAKS
skunkwhat
08-19-2004 04:55 PM
