Idle problem, need help
97 cx with absolutely no mods except a short ram intake, and i have an exhaust leak, it started idling really low at around 200-300 yesterday, do you think it's my exhaust leak???
Re: Idle problem, need help (akaEsCo01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akaEsCo01 »</TD></TR><TR><TD CLASS="quote">97 cx with absolutely no mods except a short ram intake, and i have an exhaust leak, it started idling really low at around 200-300 yesterday, do you think it's my exhaust leak???</TD></TR></TABLE>
was your A/C on at the time?
Re: Idle problem, need help (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">was your A/C on at the time?</TD></TR></TABLE>
Good question! - Also, what do you normaly idle at?
Re: Idle problem, need help (yonnage)
my car does the same thing, ive replaced the plugs, plug wires, rotor and cap. A new thermostat and new radiator(autozone 100 bucks dual core ). and cleaned out the IACV numerous times. dont' know what the problem is yet, most likely the IACV but i can hold out from spending 200+ bucks on a new one for a while. post if it gets fixed.
Re: Idle problem, need help (sleepyhamsterlx)
I thought that if you had a faulty/dirty IACV, it rev'd higher, not lower. Did you try pluging the hole to see if it makes a difference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yonnage »</TD></TR><TR><TD CLASS="quote">A/C = Air Conditioner</TD></TR></TABLE>
i knew that is was a joke...cx's don't come equipped with a/c for the most part, anyway, you think too much oil will cause the low idle, it looks like i am a quart over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akaEsCo01 »</TD></TR><TR><TD CLASS="quote">i knew that is was a joke...cx's don't come equipped with a/c for the most part, anyway, you think too much oil will cause the low idle, it looks like i am a quart over</TD></TR></TABLE>
I am not quite sure, but you prob shouldn't be over When did you do your last oil change?
could be timing, throttle cable, or iacv. but since you say the only thing done to your car is an intake i dont think it would be any of those except maybe iacv. exhaust leak shoulndt effect idle.
I am not quite sure, but you prob shouldn't be over When did you do your last oil change?</TD></TR></TABLE>
i went to jiffy lube and got one today when i thought it couls be the oil level, so i have been driving around for some errands and it has been back to normal, but i'll know for sure when i drive to work on wednesday...45 minute drive should be a good test
nicarusthegreat
01-02-2008 02:30 PM
