"JDM" EG headlights
"JDM" EG headlights
whats the difference between the USDM headlights and the JDM ones for the EG. i see that theyre plastic instead of glass with the JDM, and they have the city lights. what exactly are city lights?
Re: (zanthrax)
search
but ill asnwer it
plastic covering
no nipples
city lights like what they said
also i noticed that the headlights beam alot better then the usdm ones
but ill asnwer it
plastic covering
no nipples
Re: (vsmEK)
most importnatly is that the jdm headlights use a H4H bulb. very few upgraded bulbs available and no one makes an HID kit for it and even stock replacement bulbs will cost you $35.00
Re: "JDM" EG headlights (Dirk Lance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk Lance »</TD></TR><TR><TD CLASS="quote">no nipples on the front! lol</TD></TR></TABLE>
See I knew you were disturbing.
Re: "JDM" EG headlights (iluvGiRls)
city lights:
low/highbeam:
hope this gives you a picture of city lights. if you need help search my DIY EG headlights and it'll help you out. It's plug and play.
low/highbeam:
Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">I thoght the city lights only illuminated the housing. Which would make them a bit diferent from DRLs.</TD></TR></TABLE>
DRL's are technically the headlight bulb running at a lower percentage of power than normal...
City lights are just that... city lights... DRL's are on when the power is on and lights are all the way off... city lights light up when the parking lights go on...
Also to the poster.. FYI
JDM headlights also use h4h headlight bulbs which are not available in the U.S. I believe there are some vendors that sell them now but at a premium
SDM (Singapore DM) have the city lights... have GLASS lenses with no nipples, and take normal h4 bulbs...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvGiRls »</TD></TR><TR><TD CLASS="quote">
See I knew you were disturbing. </TD></TR></TABLE>
God damnit will you get off my nuts!??!?!
i also have picture on my sig
i dont have my corners wired up so its actually different from the ones u see above
i was told this is how the eg6 looked like with the headlights i like it better this way but what em i to say =P
take a look pm me if u need help
God damnit will you get off my nuts!??!?!</TD></TR></TABLE>
Re: (zanthrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax »</TD></TR><TR><TD CLASS="quote">city lights are what you would call running lights.
it's a small extra bulb in the headlight.</TD></TR></TABLE>
acutally that not true at all
running lights, as you know in the USA are mainly for safety purposes when driving ( let other drivers see you coming) and come on automatically when driving
city lights are used in the city, are not automatic, and are used when driving in the city. the purpose is so that when you get to an intersection, you turn off your main lights so as though you dont blind the driver across from you. once you get deeper into the city, and its alot brighter ( see any picture from tokyo at night), you just use these lights as the city around is well illuminated from all the buildings
hope that cleared up any confusion
Re: (R you serious)
Do the EDM headlights produce as good an output as the JDM headlights? Also, I know the EDM headlights are rather expensive but do you know where they can be purchased?
Re: (REVHARD_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF »</TD></TR><TR><TD CLASS="quote">You guys realize that plastic lenses discolour over time right? Take a look at a 1990 Mustang LX.</TD></TR></TABLE>
i believe you cause it makes alot of sence but uh dont u think if it would start to discolor by now its been like 10 years or so from
i herd a part of the headlights start peeling but never herd of it discoloring or seen it =/
Re: (White93Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White93Civic »</TD></TR><TR><TD CLASS="quote">Do the EDM headlights produce as good an output as the JDM headlights? Also, I know the EDM headlights are rather expensive but do you know where they can be purchased?</TD></TR></TABLE>
Honda Europe, about 215 euro each. They are expensive because they are motorized, you can raise and lower them from the cabin. Also in Europe the "city light" is used for parking , so other cars can see the edge of you car since street cans be very tight.
