low on gas...tuff start!!!
does n e one have this problem with their ek's? well i do. but it does start up if push the car and get some gasoline moving. what's the main problem though? help me out here peeps!
Re: low on gas...tuff start!!! (punkassazn)
first off letting your gas that low is hard on the fuel pump and sucking up dirt from the tank. The reason it takes so long to start it is that the pump can't suck it up right away and it has to build up pressure to send it to your engine. Fill up a little sooner and you won't have that problem.
1 Post
Re: low on gas...tuff start!!! (Kista20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kista20 »</TD></TR><TR><TD CLASS="quote">first off letting your gas that low is hard on the fuel pump and sucking up dirt from the tank. The reason it takes so long to start it is that the pump can't suck it up right away and it has to build up pressure to send it to your engine. Fill up a little sooner and you won't have that problem.</TD></TR></TABLE>
Werd. My friend runs his CRX to bone dry all the time, I don't know why.
Keep some gas in there even those gas prices suck.
Re: low on gas...tuff start!!! (The G2 Racer)
just make sure u put the car in the on position and let the car prime wait till the little engine light goes off THEN crank it and there shouldn be any problems
Re: low on gas...tuff start!!! (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">why the second thread n00b?</TD></TR></TABLE>
didnt even see this one sorry to keep the second one alive
yes correct
thats all folks
yes correct
thats all folks
Re: low on gas...tuff start!!! (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">just make sure u put the car in the on position and let the car prime wait till the little engine light goes off THEN crank it and there shouldn be any problems</TD></TR></TABLE>
That's what I do when I know I am low on gas.
Re: low on gas...tuff start!!! (EL Vap133)
thats correct also
thats correct also
Do you have a FPR, because if you do somtimes if its a cheap one like weapon R it is hard to start, but that was just my experince. (reverted to the b&m FPR )
Also, if your low on gas you might want to fill up and dont come in here and ask if its hard to start when gas is low thats just dumb. Turn your key two clicks and let the gas get into the lines. Then start it.
TiffanyHonda
04-09-2018 11:33 AM
cooljerk187
02-26-2004 12:42 PM
EpDarks
13
11-03-2002 06:00 PM
