Will any VSS work from a 92-95 civic on my 1994 civic si?
Guest
Posts: n/a
Hey guys, my VSS broke/stopped working so I went to the wreckers and got another VSS from another D-series civic motor. I installed it and it works great.
Does the VSS have to be the same as the one I had on my d16z6 motor??? or can it be from any model in the year range of 92-95?
Re: Will any VSS work from a 92-95 civic on my 1994 civic si? (EJ1_519)
The speedometer gear (which is part of the VSS) fits a variety of civics from 92-00 and 93-97 del sol with D-series engines. Honda part number 23820-P00-000. So, it shouldnt matter.
TSPeed Factory
Re: Will any VSS work from a 92-95 civic on my 1994 civic si? (vtecpower1062)
yes it should work. when the VSS in my B18C1 went out, i just swapped it over from my D15B7 motor.
Re: Will any VSS work from a 92-95 civic on my 1994 civic si? (Ricey McRicerton)
as far as i know the only ones that wont work are the automatics, just because the little machine part of it is to long to fit in the hole. i tried a bunch when mine went out..... still broken to this day.
all *electronic* VSS's function the same, and for the most part have the same internals. I know all manual EG/EK civic ones work, and have the same clip style same goes for the DC/ (and some) DA integras Prelude VSS's i havent messed with, but i know the clip is the same
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">How about from a 5th gen to a 6th gen? Just for future reference. </TD></TR></TABLE>
do you mean from obd-1 to obd-2? well i did notice when we swapped my friends B16A2 that the way the VSS bolts up to the tranny is slightly different then my obd-1 B18C1.
92J-SpecHatch
05-02-2006 01:35 PM
BigBlockCRX
05-06-2004 11:59 AM
