GC question...
GC question...
I'm wondering if you can put the front springs in the rear and vice versa so the rear is stiffer to promote a more neutral setup? Can you do this or is it not advisable? BTW, I got the off the shelf civic kit with agx's. Thanks.
Re: GC question... (=GAMEOVA=)
I belive the Rear springs that come with most GC setups are stiffer than the stock springs that are on the car, so if they are the same length I would swap them, it will make the car more neutral and promote oversteer, but you have to be aware of the situation before you do anthing stupid because it will bite you.
Re: GC question... (96hb)
The rears are pretty tame, I wouldn't put them up front.
The fronts are a decent street rate for the front; if anything, sell the rear springs and buy some 450s or 500s like I did.
I'm running 380f/450r with Konis, 21mm front and 22mm rear Comptech sway.
Works great at autox stuff.
Re: (rxse7n)
Well, they are different lengths so I think I'll install them correctly. If anything, I'll sell the rears and get stiffer ones if need be.
Silchuki14
Suspension & Brakes
08-05-2008 07:01 AM
Wazup
Suspension & Brakes
02-06-2006 10:46 PM
