jdm b16a gen 2 into 95 EJ coupe ALREADY SEARCHED
Ok, before i get the posts that tell me to search, I already searched, plenty of times, and I keep coming up with different information from different people. It is about time that this question finally gets answered. Myself and one of my friends are each doing 2nd gen jdm b16a swaps into our 1995 civic coupes. According to many posts and other websites, we can combine the b16 mounts and the d15 mounts in order to be able to successfully mount the b16 and tranny. Other people have said that integra mounts are needed and other people are saying that you NEED to buy mount kits. Does anyone have actual FACTS regarding this issue? I am looking for factual information, ie. you have done the swap and you know the answer. The only information that seams to be constant is that a del sol vtec a/c bracket is needed if you want to keep a/c. Factual Information is greatly appreciated.
cliff notes: what mounts are used for jdm b16a gen 2 swap into 95 EJ - already searched
Thanks
Thanks
Re: jdm b16a gen 2 into 95 EJ coupe ALREADY SEARCHED (hyperdecalsdotcom)
The stock 2nd gen b16a mounts will work, if your engine came with them there is no need to use the stock d mounts... simple.
The only thing you are hearing about combining parts is using the b16a brackets and use the rest of the stock civic mounts. Once again if your swap came with mounts, there is no worry to use the ones of your stock engine.
hth
hth
1 Post
the only mount you can use on the d15 is the upper tranny mount. otherwise all the other 4 mounts you will need to purchase
Re: jdm b16a gen 2 into 95 EJ coupe ALREADY SEARCHED (hatchi)
this is the type of mixed information I was talking about. My main problem is that I dont want to get stuck half way through my swap and not have the right mounts and be out of commission for a while.
Im not going to be wasting time on this post, ask yourself this questions. Does your b16a come with the stock mounts ? If so there is no need to worry about your d15 mounts period....
Terry_shum
11-17-2003 04:18 PM
