00' si got broken into...
I was in Vegas this past weekend only to find out that my 2000 si got broken into.
My Viper alarm was activated with an autolock to the clutch pedal in addition to a kill switch that was secretly hidden. It appears that there were two guys involved.
I can say for sure that these guys were newbies from the way everything looks.
They managed to break the lock assyembly, bent the clutch pedal far right, removing the autolock, and cut the alarm wire from the battery, but didn't have any clue to bypass the kill switch. Replacing the broken parts are no problem. the only problem I have now is power. I mean no sign of power from the battery. The battery is still good. What could it possibly be because there were no damage to the battery as far as i can see. Could they possibly remove a fuse or something in order to come back later and do the unfinish work? Any help will be nice guys. This will save me money from going to the Honda dealer.
Regards,
Klo
Regards,
Klo
B A N N E D
Re: 00' si got broken into... (klomast3r)
check all ur fuses inside and outside the car, that would be a good start. and hopefully you rewired the wires back to the correct ones.
like DvD3 check all your fuses inside and outsitde. may i suggest to all CALI heads to always valet your car in vegas. i live here and number one spot to get jacked is on the strip especially if you are out of towners.
VI Boost
Audio / Security / Video
18
12-25-2009 06:54 AM
sagron69
12-01-2005 02:08 PM
