brakes ......... help
i have a 97 DX coupe that im planning on putting a B18C5 in, i have already looked in to better suspension and sway bars but now i need some advice on brakes.
ive looked at tenzo and AEM big brake conversions but no-one seems to list the for a DX.
any help would be great
Dont waste your time/money on kits.
Get a set of em1/ex/integra/del sol vtec/si knuckles and do an integra brake swap. You'll have larger (57mm) caliper pistons and larger diameter rotors. Add a larger master cyl and booster and call it done.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Dont waste your time/money on kits.
Get a set of em1/ex/integra/del sol vtec/si knuckles and do an integra brake swap. You'll have larger (57mm) caliper pistons and larger diameter rotors. Add a larger master cyl and booster and call it done.</TD></TR></TABLE>
And with money to burn afterwards too.
F big brake conversions.
Re: (pdiggitydogg)
So true. They might not look as cool behind your rims, but that's not what brakes are for. If you plan to track the car look into some good fluid ( I run ATE Super Blue) so you don't end up cooking the fluid. The super blue is good because they sell super gold (same stuff, just a different color) and you can completely flush the brake system and tell when all of the old is out.
del spool
03-30-2010 10:54 AM
duh blacksheep
12
04-26-2005 07:53 AM
