just finished my swap but need help on SOme BUGS
ok well i jus finished my swap for my 95 civic si and i put in a jdm b16 sir2 in it and now it just idles funny like it keeps bouncing from 1 all the way to 4 and back down to 1 is there anyway to make it idle normaly im also running a chipped p28 other then that the motor is stock any help would be appriciated
Re: just finished my swap but need help on SOme BUGS (Eg6xCiViCxSi)
there quite a few things that can cause stuff like that....
Check for:
Vacuum leaks
Wiring problems
as these are very common.
i'm not sure what else to tell you, there are jsut too many variables.
Check for:
Vacuum leaks
Wiring problems
Re: just finished my swap but need help on SOme BUGS (JDMallTHEway)
ive checked the wiring and that wasent the problem we tested all of them and they had power goin to them but im thinkin it is a vaccum leak because when i put my hand on the throttle body the car doesnt die what can cause that? vaccum leak probaly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6xCiViCxSi »</TD></TR><TR><TD CLASS="quote">ive checked the wiring and that wasent the problem we tested all of them and they had power goin to them but im thinkin it is a vaccum leak because when i put my hand on the throttle body the car doesnt die what can cause that? vaccum leak probaly?</TD></TR></TABLE>
vacuum leak for sure.
a bad AICV will cause this as well.
Re: just finished my swap but need help on SOme BUGS (Relic1)
Im going with bad Vacuum somewhere, check all your lines off the intake manifold and such, I had a similar problem on my prelude.
Is there any CEL's? if not im stickin with bad programing. I know several people who bought bogus chipped ECU's and they have the wrong maps, and Raised the IAC duty cycle to 100% so that its runnin all the time.
Re: (JDMlyfestyle)
the sir2 intake manifold doesnt have a map on it if im correct... and hes not running the p30... and a p28 calls for a map... if he doesnt have an external map could that be the prob?
Modified by neutron91 at 8:03 PM 5/16/2005
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">
a bad AICV will cause this as well.</TD></TR></TABLE>
probably not a vacuum leak....vacuum leak would hold constant high idle
IACV is mostlikely the problem or air in water lines
Moderator
Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">the sir2 intake manifold doesnt have a map on it if im correct... and hes not running the p30... and a p28 calls for a map... if he doesnt have an external map could that be a prob?</TD></TR></TABLE>
if there is no MAP hooked up then this is a problem that needs to be fixxed
Re: (JDMlyfestyle)
the chipped ecu was in my friends car and his ran just fine we checked that part and its not the ecu im jux thinking its a vaccum leak somewhere i will go out tommorow and check all of the houses 1 more time shouldnt my car die if i cover my throttle body? cuz it doesnt and my friends say it should
fastblacks2k
11
01-25-2010 12:22 PM
PDXHatchback
02-10-2004 10:16 AM
