Del Sol cruise, nad fuse help
Ok, i bought this del sol si yesterday. I took out all the system wiring and stuff, and fixed my Aux lights with a fuse and all that stuff. But i need som ehelp
Does everyone else have the Plug in the top left of the interior fuse box there, as well as the top right relay it looks like.
Also there are five single prong plugs numbered 5,4,1,2,3.
Is there any way you can help me by posting a fuse diagram like whats on the inside of the little pop off door, that i dont have. and a haynes manual doesnt either. id greatly appreciate it
Also my Cruise wont come on. Liek there is no power to it, thats why id also like a diagram of the different fuse lacations so i can troubleshoot that one.
Any help would be appreciated. thanks guys!
Re: Del Sol cruise, nad fuse help (tsispyder97)
theres a total of 3 fues you need to check:
Fuse#24 15amp ACG? (UnderDash)
Fuse#15 10amp Backup Light (UnderDash)
Fuse#42 15amp Stop, Horn (UnderHood)
Hope that helps you I got that from a 97 honda wiring guide. It showed all three of those giving power to the system in some respect.
Re: Del Sol cruise, nad fuse help (nocturnaldragon)
where in the manual is that? Im trying ot find it but i cant. fuse 22 keeps blowing, im tryign to find out what that is
its in a wiring book for the car, that fuse is for your left headlight - low beam. according to the diagram its a red/white wire that goes into the fuse cluster then it goes into the fuse and turns into red/yellow and runs directly to your left headlamp.
My suggestion is look in the wire loom under the hood near the head lamp. You probably have a short to ground somewhere in there.
TurboTim10
04-10-2010 10:33 AM
wrx'n you
07-10-2005 07:38 PM
Apocolipse269
09-07-2004 07:18 AM
