About How Much Would It Cost to Replace a ripped cv boot?
why would he mean shift when he asked cv?
They sell quick replacement boots at autozone for under $20.
Depending on how long its been ripped, you really should just replace the entire axle ($50 or so after trade in @ autozone) because dirt may have gotten into the joint = premature wear = dead joint soon = more money and time to do it a second time
Electrician
Re: About How Much Would It Cost to Replace a ripped cv boot? (Cboy1-EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cboy1-EG6 »</TD></TR><TR><TD CLASS="quote">CV boot? Do you mean shift boot?</TD></TR></TABLE>
CV boot and shift boot are 2 different things. CV boot is part of the axle. Shift boot is part of the shifter.
CV boot:
Shift boot:
Bling blao.
CV boot:
Shift boot:
Bling blao.
Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">yea i would replace the entire axel</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">replace the entire axel... don't put a bandaid on it.</TD></TR></TABLE>
Moderator
Re: About How Much Would It Cost to Replace a ripped cv boot? (VTECsound)
just get a new axel....59.99 and do it yourself.....
fastest axel change
6 minutes at the race track!
fastest axel change
Moderator
Re: (runnin9z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runnin9z »</TD></TR><TR><TD CLASS="quote">it going to be easyer in the long run to replace the entire half shaft</TD></TR></TABLE>
his CIVIC does NOT have a half shaft unless he has a swap....
and you wouldn't replace a half shaft....i have never seen one go bad!
Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">with axles as cheap as they are, screw the freakin boot
get a new axle</TD></TR></TABLE>
yup and if u have a lowered car, u might as well the lifetime warrentied ones from any parts store
Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">
yup and if u have a lowered car, u might as well the lifetime warrentied ones from any parts store</TD></TR></TABLE>
I belive this has been answered numerous times...SEARCH!
As long as I dont have to take out any more Metal Gears
Re: (DJ_CARY)
replace the axle, changing the boot will follow the same process as changing the axle. Might as well cuz it seems like u are due for an axle change anyways. Hey its just like a timing belt job, While everythings out u may as well change the water pump and crank seal, u do this to avoid future problems.
Re: About How Much Would It Cost to Replace a ripped cv boot? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">fastest axel change
6 minutes at the race track!</TD></TR></TABLE>
that's pretty good .. i did it in 20 minutes and i though i was fast.
replacing the boot takes like an hour and you have to (well not have to ... but it would suck) pull the axle out anyway. and i hate dealing with axle grease.
go to napa and get a new one with a lifetime warranty for 60 bucks and be done with it.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I can change an axle in about 20mins Id say.
A lot faster since I started popping the lower ball joint w/ the ratchet </TD></TR></TABLE>
Same here. There is a VIDEO on how to do it. ******* great! Best thing that i have come across on honda-tech to date was that video.
Re: (eg cookiemonster)
best advice today
best advice today
Re: (patastinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky »</TD></TR><TR><TD CLASS="quote">Same here. There is a VIDEO on how to do it. ******* great! Best thing that i have come across on honda-tech to date was that video. </TD></TR></TABLE>
Where is this video? My search-fu didn't work.
just replace the axel...less headache...i had that same problem and i you can do it yourself it's pretty easy to do
