short shifter helpp
short shifter helpp
have the short shift . tried to install . took off 2 bolts from shift linkage now it wont come down . did i forget anything? or is it jus the exhaust piping blockin its way down ?
thnx
thnx
Honda-Tech Platinum Member
Re: short shifter helpp (phackdat)
go here https://honda-tech.com/zerothread?id=944804 this will definitely help you out... when I installed mine on I didn't have to remove my stock exhaust, I just pulled out the shifter at an angle
for the quick answer, there are two more bolts you missed. they hold a plate up that holds the ball join fulcrum point of the shifter. crawl under. its a pain in the ***. pending on the condition of your car, you might have to drill out the bolts, thats what i had to do with mine, then i just used two machine screws and bolts to put it back together. easy as pie!
Ricey McRicerton
03-09-2009 03:18 PM
phreaker
11-07-2002 08:46 PM
