LOUD AZZ WHINING FROM DEAD STOP
A few days ago I started hearing this loud *** whine sometimes when I would get on it from a dead stop. At first i thought the tires might just be rubbin but I didn't see anything. Could it be the differential??
Re: LOUD AZZ WHINING FROM DEAD STOP (1sick_eg)
Does it do it when you take off from a stop, like as you're letting out on the clutch?
Have you replaced your clutch recently, flywheel?
Re: LOUD AZZ WHINING FROM DEAD STOP (******)
Not recently I haven't no... I am this weekend so maybe I'll find somethin loose i don't know. It kinda sounds like somethin is rubbin together becuz it gets louder as thr rpm's go up but as soon as i let off it stops completely. I can dump it from a roll and it not do this but when I dead stop it makes this noise most off the time.
I would have said that you were driving a mustang with a whipple charger on it but then I remembered that I was on Honda Tech
All joking aside let us know what you find out when you replace the clutch. You may want to consider a little bit of brake rub possibly? Just another thought.
Re: LOUD AZZ WHINING FROM DEAD STOP (ralphie14)
are your belts tight (alt, ps, ac)? you should have about 1/2" of play in them or so. If they are too loose, the belts will squeal on startup and while accelerating.
Re: LOUD AZZ WHINING FROM DEAD STOP (IHateJDM)
No its not the belts...checked em.....thanks tho....this whine is so loud right before i let off it sounds like somethin is about to break
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sick_eg »</TD></TR><TR><TD CLASS="quote">No its not the belts...checked em.....thanks tho....this whine is so loud right before i let off it sounds like somethin is about to break </TD></TR></TABLE>
Sounds like a belt to me though. Does it stay constant?
Oil level alright? Oil pressure? Have oil in the tranny?
I can't really think of anything else that would whine.
Re: LOUD AZZ WHINING FROM DEAD STOP (nothing)
it only does in fist gear from a dead stop and only sometimes....I can do a first gear roll and it doesn't do it
does it only whine in a certain gear? could be tranny synchros.
*Edit: you answered my question while i was writing it. I'm thinking synchros.
Zeino
03-30-2011 01:36 PM
luder22
10-21-2004 12:59 PM
Andrew 825SM
11-23-2003 09:34 AM
Ross
31
05-08-2002 02:04 PM
