*UPDATE*--on my ecu i decided imma try on my own...
alright people after my bro telling me 70$ to install ecu is rip-off, i've decided to do it myself if you didnt see last post i am installing 2000 acura integra type-r ecu into my 00 civic si...my question is there any manuals out there that would show steps? maybe helms..or haynes anyway my brother said irs pretty much common-sense...anybody have any good insight or thoughts on maybe what
---i should be prepared to encounter..
---what not to do
--any good info will help but for now im gonna pick up helms and haynes anyway at kragens..like i said tho any and all info would be great thx..
---what not to do
changing the ECU?
You mean pulling back the mat, unplugging the 2 plugs from the old ECU, and plugging in the 2 plugs into the new ECU?
Then putting the mat back into place.....
Re: (Syndacate)
i dont know about a mat, but on my ej8 (assuming its the same as Em1) its behind the passenger side kick panel. there is one screw/snap on the side and one screw/snap towards the back and up top. remove panel ecu is then in a bracket behind that.
Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">ill do it for you for 30.</TD></TR></TABLE>
ill do it for 29
ill do it for 29
Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote"><u>i dont know about a mat</u>, but on my ej8 (assuming its the same as Em1) its behind the passenger side kick panel. there is one screw/snap on the side and one screw/snap towards the back and up top. remove panel ecu is then in a bracket behind that.</TD></TR></TABLE>
You mean the one screw/snap on the mat that holds it down?
I'll do it for lunch at In-n-Out (you'll have to fly me out to get it, of course)
Theres a plastic tab on the side of the kick panel, and a "screw" plug at the top (at the firewall).
From there, you kinda rotate the kickpanel counter-clockwise to remove it.
There, you'll see your ecu.
Remove the 10mm bolt holding it. Unplug the connectors (AFTER you disconnected the battery) and replace with the other ecu.
Enjoy the pointless swap...because it wont do squat on your em1
Re: *UPDATE*--on my ecu i decided imma try on my own... (em1honda@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1honda@yahoo.com »</TD></TR><TR><TD CLASS="quote">alright people after my bro telling me 70$ to install ecu is rip-off, i've decided to do it myself if you didnt see last post i am installing 2000 acura integra type-r ecu into my 00 civic si...my question is there any manuals out there that would show steps? maybe helms..or haynes anyway my brother said irs pretty much common-sense...anybody have any good insight or thoughts on maybe what
---what not to do
--any good info will help but for now im gonna pick up helms and haynes anyway at kragens..like i said tho any and all info would be great thx.. </TD></TR></TABLE>
Is this 2000 Type-R p73 ECU a USDM spec ECU? If so, good luck with getting it to start in a Civic. 2000 & 2001 Integra ECUs = IMMOBILIZER. In order to stay OBD2b, you need a 1999 P73 or have the immobilizer removed and then deal with the CEL that's going to come on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I'll do it for lunch at In-n-Out (you'll have to fly me out to get it, of course)
Enjoy the pointless swap...because it wont do squat on your em1</TD></TR></TABLE>
x1000. Not to mention you're running an ECU designed for a 1.8 liter with a 1.6 liter engine. You're going to be running EVEN MORE rich than usual, which Hondas are notorious for, so that alone will rob your B16 of both power and gas mileage. Do yourself a favor and don't even bother trying to install it. Sell it and buy an intake or something...
---what not to do
mita
08-28-2014 11:46 PM
_HANS
06-13-2004 03:33 PM
