HELP! ENGINE SWAP WONT FIRE! cant figure it out! gettin spark n fuel?!
Old 12-04-2006, 07:29 PM
turbotime's Avatar
Default HELP! ENGINE SWAP WONT FIRE! cant figure it out! gettin spark n fuel?!
Ok so i just got my ls swap in but the damn thing wont fire ive tried everything and cant figure it out-
- I did a compression test and got 90psi solid across all 4 cylinders [17f outside] and the compression tester was soaked with gas.
- I checked the plug wires for spark and was getting spark on all 4 wires.
- For some reason the plugs are getting drenched in fuel so i replaced all 4 spark plugs, still no start
- replaced the plug wires and battery, still nothing
- no cel's
i cant figure this out? It seems like its just dumping fuel, there is no o2 sensor attached but that shouldnt effect startup...
92 b18a1 stock, obd1 stock ecu
HELPP PLEASSEE
Old 12-04-2006, 07:52 PM
Blk00EJ8's Avatar
Default Re: HELP! ENGINE SWAP WONT FIRE! cant figure it out! gettin spark n fuel?! (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i just got my ls swap in but the damn thing wont fire ive tried everything and cant figure it out-
- no cel's
HELPP PLEASSEE </TD></TR></TABLE>
90 psi solid?? for one, that's really low, even for the temp. and two, you're supposed to disconnect the injectors when you do this. you did something wrong with readings like that.
the reason it's probably not starting is because you're probably flooding your engine with too much fuel. what's the fuel pressure after the pump primes? and what size injectors? with a stock ecu you shouldn't be running anything larger than oem sized injectors.
Old 12-04-2006, 07:55 PM
turbotime's Avatar
oem injectors, idk fuel pressure there is no gauge but the pump is priming.. i did the test by disconnecting the dizzy, WOT remove one plug at a time and cranked it like 10 times per cylinder...
should i pull the plugs and let it sit overnight to evaporate the fuel?
Old 12-04-2006, 08:29 PM
turbotime's Avatar
bump, pulled the plugs and im gonna let it sit overnight...
plugs are covered in fuel, no sing sof combustion at all
Old 12-05-2006, 07:43 AM
turbotime's Avatar
bump wtf got some partial combustions today but the cylinders are just getting flooded with gas, the plugs are literally wet with gas when i pulled them out
Old 12-05-2006, 08:01 AM
I Shot 50 Cent's Avatar
Shouldnt the ideal compression for an LS be in the 180 range? Or is that 120?
This could be really simple...but are all your grounds connected properly? Even the one on the valve cover many people seem to forget about.
Good luck!
Old 12-05-2006, 08:06 AM
turbotime's Avatar
yup got all the grounds (tranny, valvecover, thermostat)...
if i touch the injectors gas starts comin out of the rail, could the injector seals cause the car not to start? Im thinking of swapping dizzy's even tho im seein spark when i help the plugwire near a screwdriver, will an obd1vtrec dizzy work on this motor?
My last guess is maybe the valve lash is way off?
Old 12-05-2006, 10:11 AM
Sloshy's Avatar
timing might be off
Old 12-05-2006, 10:24 AM
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">yup got all the grounds (tranny, valvecover, thermostat)...
My last guess is maybe the valve lash is way off?</TD></TR></TABLE>
Hmm...Im pretty sure if the valve lash is off, even pretty moderately it should still fire. It won't idle very nicely but it should still at least turn over. Are you certain the timing is set correctly? Fuel pump is good along w/ the fuse/relay?
Good luck man. I HATE situations like this. You finally got your motor swapped and you're soooo excited to whip it around but something bullshit like this comes along and screws it all up. Not to mention its cold as expletive outside...well at least in NJ it is. Actually, you're in upstate NY. I actually think you guys got snow right? Can't be a comfortable working environment, thats why I say it could be something relatively simple since you're probably anxious, cold, worried, and in a rush all at the same time. Have patience though man, it'll get figured out!
Old 12-05-2006, 11:01 AM
cranny's Avatar
Default Re: (I Shot 50 Cent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent &raquo;</TD></TR><TR><TD CLASS="quote">Shouldnt the ideal compression for an LS be in the 180 range? Or is that 120?
Good luck!</TD></TR></TABLE>
wouldnt turn over if that was the case , wouldnt effect starting. firing order wrong maybe? somin silly prolly. cant get no easier than a plug and play swap which is what that is pretty much. couple diffs in ECU wiring though.
heres somin to look at , the D ECU connector for OBD1 civics
D01 7.5A backup fuse.
D02 green/white , BKSW(brake pedal switch)
D03 LABEL(laf sensor , Z1 engine only)
D04 brown , SCS(service check connector)
D05 not used
D06 orange/blue , VTM(vtec oil pressure switch , for D16Z1 and D16Z6 engines)
D07 light blue , TXD/RXD(data link connector)
D08 VS+(laf sensor , Z1 engine only)
D09 white/yellow or pink , ACGF(alternator)
D10 green/red , EL(eld unit)
D11 TPS - throttle position sensor
D12 white/black , EGRL(egr valve lift sensor, for D15Z1 only)
D13 red/white , TW(tw sensor , tied into data link connector)
D14 orange/black , heated O2 sensor(for B7 , Z6 , Z1((IP+ also)), engines) ; O2(non heated , for B8)
D15 red/yellow , TA(ta sensor , tied into data link connector)
D16 orange/black , IP-,VS-(laf sensor)
D17 not used
D18 pink/green , SIL(shift up indicator , m/t) , white/red (interlock control unit , a/t)
D19 VCC1(map sensor)
D20 VCC2(egr valve)
D21 SG1(map sensor)
D22 SG2(connected to all engine sensors for data link connector)
and for OBD1 tegs
D01 - white/blue - 7.5a backup fuse in under hood fusebox
D02 - green/white - brake pedal switch
D03 - red/blue - KS(knock sensor)
D04 - brown/white - service check connector
D05 - empty
D06 - blue/black - VTEC pressure switch
D07 - light blue - data link connector
D08 - light green - TCM(A/T only)
D09 - white/red - alternator
D10 - green/red - ELD(electronic load detector)
D11 - red/black - TPS(throttle position sensor)(TCM also for A/T)
D12 - empty
D13 - red/white - ECT(engine coolant temp sensor)(TCM as well for A/T)
D14 - white/red - H02S(heated oxygen sensor)
D15 - red/yellow - IAT sensor
D16 - white/black - TCM(A/T only)
D17 - white/yellow - MAP sensor
D18 - empty
D19 - yellow/white(than yellow/red from tower plug for LS , yellow/white all the way for GSR) - MAP sensor
D20 - yellow/blue - TPS(throttle position sensor)
D21 - green/white - MAP sensor
D22 - green/blue - H02S(heated oxygen sensor)
Old 12-05-2006, 11:51 AM
turbotime's Avatar
cam timing was off as hell, im in the process of correcting it, should be much better once its correct
Old 12-05-2006, 05:07 PM
turbotime's Avatar
<FONT SIZE="5"> UPDATE</FONT>
Ok fixed the cam timing and adjusted the valve lash. Apparently the alternator was seized so i ordered a new one.
Jumped the car off a buddy's and got it RUNNING! But it sounds like a 4stroke dirtbike or snomobile, running SUPER RICH. Everything on this car is stock i have no idea wtf is wrong...
Pulled the plugs- soot black. Checked the compression- 180psi across the board.
HELLLPPPPP
Old 12-05-2006, 06:23 PM
turbotime's Avatar
what would it run like if my camt iming were off a tooth?
Ek9_Cuhzz
58
01-07-2011 04:54 AM
anht
13
05-01-2010 11:57 AM
ksprelude01
03-27-2008 07:05 PM
stp_vtec_boi
08-23-2006 09:06 PM
smallttocs
05-25-2004 08:39 PM
Quick Reply: HELP! ENGINE SWAP WONT FIRE! cant figure it out! gettin spark n fuel?!
