Need help A.S.A.P with motor
Alright were to start, i had a y8 motor on my 98 civic ex, with p2p ecu. Now here's were the problem... i had to get a swap=jdm d15b for my over heating issues with the y8, blown head gasket. Now the swap was not to hard is that i already know that i had to swap my dizzy for wiring issues, but did not know i had to swap out my old y8 intake mani, and my old y8 knock sensor, and my fuel injectors. So now by taking off the timing belt to put in the knock senser... i think the timing went off by doing that or my engine needs some serious tuning. So now driving the car is a B****, car is slow as a snail... wtf. Taking off from first gear is crazy car wants to stall i would have to double clutch it so i could jump the rpm a little bit... and when i try to run it ("I COULD OFFICALLY SAY THAT MY CAR IS LOUD FOR NOTHING") the rpm,and the mph gauges moves slow. I also brought it to autozone its throwing codes like system is running too rich, knock sensor is defective, and o2 sensor for my intake. So now my questions is what could be making my car run sluggish like that... any good advice,tips,knowledge... it would really help, i need my car to go to work/school ASAP... thanx
also im using my p2p ecu, could that be a problem??? v-tec is also not kicking in @ all???
Re: Need help A.S.A.P with motor (jdm_ek_Coupe954)
If you want to remain OBD2, you are going to have to fix all those codes.
I would personally switch to OBD1 and not have so many issues. You won't have to have the second O2 sensor, CKF sensor, or the knock sensor.
Also what distributor are you using?
Re: Need help A.S.A.P with motor (F20Cteg)
These are the codes that its throwing
1. O2A - Oxygen sensor #1, or #2 cant remember
2. Knock sensor is defective
3. P0172 Fuel System Too Rich
I'm using my obd2 dizzy, for harness issues... do you think i could get those codes fixed???... and do you think could my timing be way off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ek_Coupe954 »</TD></TR><TR><TD CLASS="quote">Alright were to start, i had a y8 motor on my 98 civic ex, with p2p ecu. Now here's were the problem... i had to get a swap=jdm d15b for my over heating issues with the y8, blown head gasket</TD></TR></TABLE>
you HAD to get a swap due to a blown head gasket???? why didn't you just pull of the head and replace the head gasket? If you are knowledgeable enough to do a swap, then I'm sure that you could have just done a simple head gasket replacement instead.
