Sway Bay Question for 92 Civic
Sway Bar Question for 92 Civic
What OEM sway bar from an Integra would fit my 92 H/B w/ Omni LCA. Not trying to go big coz I don't have a subframe brace that would support it.
Did searched..
Help is greatly appreciated.
Modified by grayegcivic at 3:11 PM 12/5/2006
Did searched..
Re: Sway Bar Question for 92 Civic (grayegcivic)
any 94-01 integra sway will fit ur car. jus get gsr or sumthin i believe they are 14mm which is no problem for ur car.
If you use a teg front sway your going to need to change the 2 main front bushings & I think the metal brackets. I think I bought all new Energy Suspension bushings (end link & mains) from http://www.suspension.com for about $12-$15 shipped.
Depending on which bar you get you may need to change endlinks too. Some of the 24mm fronts use an "L" shaped endlink versus what you already have. I have the "L" shaped ones, & they were about $80 from acura. Im not sure on the specifics, but some of the others (99-00 si maybe) use your same endlinks.
Search the suspension forum here on h-t & theres all kinds of more info on it.
jpb105079
07-14-2004 06:19 AM
BNavZ
15
02-19-2004 08:20 AM
