Which axles
Which axles
i have a 94 eg hatch dx and it has a jdm b16a2 engine swap. what axles do i use?
i have axles from a delsol of the same year in with the b16 but there is a bad vibration in the 2000-3500 rpm range of 1st through third. is there anything i can do to fix this? i have been told there is some sort of clip at the end of the axle which has to be taken off. will this fix it?
if you can answer any of these questions i would be really appreciative. thanks
cute little bastard
Re: Which axles (eguser)
any 94+ Integra axle will work
You probably need an alignment, never heard of a clip at the end. Unless you're talking about the ABS thing which doesn't really matter
Re: Which axles (SkoundrelUSA)
Thanks. the guy i'm buying it from figured that since the delsol had the same engine that it would also have the same axles i guess i can bargain the price down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">any 94+ Integra axle will work
You probably need an alignment, never heard of a clip at the end. Unless you're talking about the ABS thing which doesn't really matter</TD></TR></TABLE>
Re: Which axles (RED-EJ1)
fantastic news! i work at advance autoparts and i was checking our computer system and i have found that the axles off of a 94 del sol vtech are exactly the same as that off of the same year any model integra. which means it is just the axles are bad and just to edit my first post the clip or washer is supposedly not on the axle but instead inside the hub assembly so thats why it hadn't been heard of hopefully. thanks for yalls help ill keep it updated of the status of the problem and i will hopefully have the car by like monday of next week or sooner. (im just waiting for the check i was paid with for my old car to go through the bank)
pnwjdm
12-23-2012 08:57 PM
