d16Z6 questions
d16Z6 questions
i have a 93 delsol si and the idel is at 600....is that close to where it should be and is there anyway i can make it idel higher? so it doesnt shake the car at idel? and so when i turn the wheel at stop the car doesnt allmost stall
any help would be great thanks
Re: d16Z6 questions (BlueIntegraBoy)
thats not a good idea. fix whats making it idle low. and if you absolutely must adjust the idle , theres a screw for that. dont tighten the throttle cable , lol.
Re: d16Z6 questions (macfadyen)
if you idle and the car is not moving, and you move the steering wheel, it will lower the RPMs because the pump has to work harderand the engine speed is decreased due to the strain.
Thats how i see it
I don't think your idle is wrong.
Thats how i see it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cranny »</TD></TR><TR><TD CLASS="quote">thats not a good idea. fix whats making it idle low. and if you absolutely must adjust the idle , theres a screw for that. dont tighten the throttle cable , lol.</TD></TR></TABLE>
i agree....find out why the idle is low first...unplugg the iacv and see if it stalls....if it does than its gotta be your timing....if it doesnt stall play around with your dizzy and see if you can adjust the spark timing and raise the idle to where is should be. .....how is top end performace? how does your car respond to WOT? when was he last time you had a tune up? air filter? plugs? do you have a check engine light? if all of those are good than dont worry about and just use the idle adjustment screw....flat head that sits almost fluch with the throttle body on the side where the intake attatches to.
Re: d16Z6 questions (freakasis)
under your hood read the lable.... it says stock idel is 650 + - 50 rpm's
keep it the way it is.... thats a good idel. if it aint broken, dont fix it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis »</TD></TR><TR><TD CLASS="quote">
...if it doesnt stall play around with your dizzy and see if you can adjust the spark timing and raise the idle to where is should be. </TD></TR></TABLE>
I hope when you say "play around with" you mean "use a timing light" <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">under your hood read the lable.... it says stock idel is 650 + - 50 rpm's
keep it the way it is.... thats a good idel. if it aint broken, dont fix it </TD></TR></TABLE>
As far as the power steering lowering idle, there is a pressure switch on your rack somewhere that detects if you turn your wheel, so if that is working properly, your ecu will idle the engine up a little higher to compensate for the load. Same with AC.
Re: d16Z6 questions (kuja396)
its not always the rack , most ive seen are in the pressure line , and thats exactly whats causing this prolly. unplugged or wore out.
Just a thought here... have you checked motor mounts? I had 1 loose bolt at the transmission which made mine shake at idle and slip out of 3rd sometimes.
hatchfreak92
10-17-2004 08:59 PM
