Ewwwww....dirt in brake fluid..HOW
Old 12-04-2006, 10:49 PM
sleeperrex's Avatar
Default Ewwwww....dirt in brake fluid..HOW
dirty brake fluid in booster. brakes weak...how did dirt get in?
my friend brake has been a lil weak lately. we jus opened the reservoir and the fluid is like all cloudy black , not clean and clear like its suppose to be and its too dark to take a look at it right now. Was wondering how soooo much dirt contaminated it? did it go thru the reservoir cap because it was on tight, or can it be a rip in the lines? he has SS braided brake lines btw
So tomorrow should we jus bleed the system and fill in with new fluid and see wat happens after a while? wat if it gets like taht again
Old 12-04-2006, 10:58 PM
Cory Matthews's Avatar
Default Re: Ewwwww....dirt in brake fluid..HOW (sleeperrex)
well if u sorta understand how brake calipers work. you'll see that the piston brings dust past the seals and into the fluid from there it just work's its way up to the resivour.
Old 12-04-2006, 10:59 PM
sleeperrex's Avatar
Default Re: Ewwwww....dirt in brake fluid..HOW (Cory Matthews)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory Matthews &raquo;</TD></TR><TR><TD CLASS="quote">well if u sorta understand how brake calipers work. you'll see that the piston brings dust past the seals and into the fluid from there it just work's its way up to the resivour.</TD></TR></TABLE>
so if we just bleed the whole system and put new fluid in we should be fine again rite?
Old 12-05-2006, 05:03 AM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperrex &raquo;</TD></TR><TR><TD CLASS="quote">so if we just bleed the whole system and put new fluid in we should be fine again rite?</TD></TR></TABLE>
correct
strider2
Honda CR-V & Element
05-11-2018 11:51 AM
jdm-ek-si
Suspension & Brakes
08-31-2007 07:04 AM
Balut
02-24-2005 08:31 PM
brucek2
07-12-2004 05:46 PM
Understeer
11-30-2003 10:28 AM
Quick Reply: Ewwwww....dirt in brake fluid..HOW
