cable tranny
cable tranny
They have a b18 i want to get, but its got a cable tranny.. Can yall give me some info as to where if this is a bad tranny to have .. or it doesn't matter.. whats the deal with "cable " transmission. Is it ok to go with, should i swap it out or what? let me know whats up
HT White Ops
Re: cable tranny (DSM2ner98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM2ner98 »</TD></TR><TR><TD CLASS="quote">They have a b18 i want to get, but its got a cable tranny.. Can yall give me some info as to where if this is a bad tranny to have .. or it doesn't matter.. whats the deal with "cable " transmission. Is it ok to go with, should i swap it out or what? let me know whats up </TD></TR></TABLE>
A cable transmission uses a pair of cables to change gears, whereas a hydraulic transmission uses a paired shift linkage. Your car comes equipped stock with a hydraulic transmission, and that is what you should use.
I have a 97 ek.. so a cable tranny in my car isnt even possible then?.. So if i go with the b18, what tranny would you go with or what would best suit the b18
Re: cable tranny (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">A cable transmission uses a pair of cables to change gears, whereas a hydraulic transmission uses a paired shift linkage. Your car comes equipped stock with a hydraulic transmission, and that is what you should use.</TD></TR></TABLE>
WRONG!!!!!!!!
both use a LINKAGE to change gears, HYDRO uses hydraulic pressure to disengage the clutch, and cable uses a cable.
i think you are talking about like H/F, K, etc trannies which use cable to actually change the gear, but when talking about the TYPE of transmission CABLE VS HYDRO its reffering to how the clutch is disengaged.
WRONG!!!!!!!!
Re: cable tranny (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">cable trannies wont work in a 92+ civic. you can sell it for part of the money towards a hydro B tranny.</TD></TR></TABLE>
ARE YOU KIDING ME?
i have a cable tranny in my 93 its fine.
and i also got a cable to hydro conversion and i love it
instead of using a cable to the the lever arm up
it uses the stock clutch slave cylinder and mounts underneath the arm to push it up. awesome invention.
you get a cheap tranny that acts the same as all theres!
ARE YOU KIDING ME?
Re: cable tranny (NScivic)
on other hand if you don't want to buy the cable to hydro conversion like i have.
you can just get a clutch pedal and cable from a junk yard from a older integra that had a b-series and put that in your civic.
that works as well
that works as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">ARE YOU KIDING ME?
you get a cheap tranny that acts the same as all theres!</TD></TR></TABLE>
i was talking about in STOCK form.
and yeah, i didnt even think about just swapping the pedal assembly to a cable setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">yeah well know you know if anyone else ask! </TD></TR></TABLE>
thanks.
thanks.
HT White Ops
WRONG!!!!!!!!
i think you are talking about like H/F, K, etc trannies which use cable to actually change the gear, but when talking about the TYPE of transmission CABLE VS HYDRO its reffering to how the clutch is disengaged. </TD></TR></TABLE>
Yeah, that's what I was thinking of. My mind was elsewhere I need to stop posting at work....
WRONG!!!!!!!!
Cable FTW! i just posted about this ...and found out theres a ghetto way to do it where you just mount the slave cylinder to the cable tranny....but its a good idea
Re: (EGlsVtak)
DUH...
read the form we,ve been talking about that
DUH...
onetwothreelookatme
05-06-2004 11:21 PM
