Shifter into em1
Shifter into em1
Hi guys. Just wondering will a GSR or TYPE R integras shifter direct fit into my 2000 EM1? Whats the difference between type r/gsr/LS shifter? WHich one is best in my car? Thanks!
Re: Shifter into em1 (BlueIntegraBoy)
Thanks for the info . I was thinking of getting skunk2 ss but i heard it kills your synchro! Tried to search all over h-t for info but no luck.
When i put in the gsr shifter will it be the same as putting in the short shifter or will it be the same as stock. I rather not get a SS if it kills my tranny.
Re: Shifter into em1 (dohcteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg »</TD></TR><TR><TD CLASS="quote">Thanks for the info . I was thinking of getting skunk2 ss but i heard it kills your synchro! Tried to search all over h-t for info but no luck.
When i put in the gsr shifter will it be the same as putting in the short shifter or will it be the same as stock. I rather not get a SS if it kills my tranny.</TD></TR></TABLE>
It kills your syncros if trips to the supermarket become fast and the furious. Usually syncros (and the reason you were told it'll go out) is b/c u slam it into gear b4 the clutch is fully engaged (or disengaged - point being, still partially connected).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg »</TD></TR><TR><TD CLASS="quote">I rather not get a SS if it kills my tranny.</TD></TR></TABLE>
Short shifters don't kill transmissions... idiots do.
Re: (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">short shifters dont kill syncro's. dumbass drivers kill syncros. and a teg shifter isnt going to shorten the throws anymore than your stock one.</TD></TR></TABLE>
Damn, beat me to it by a whole 46 minutes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg »</TD></TR><TR><TD CLASS="quote">Hi guys. Just wondering will a GSR or TYPE R integras shifter direct fit into my 2000 EM1? Whats the difference between type r/gsr/LS shifter? WHich one is best in my car? Thanks!</TD></TR></TABLE>
you will haft to cut the integra shifter width a bit shorter for it to fit into the linkage. the integra shifter width is thicker then the civic si shifter.
Re: (Loi-Tech)
Thanks for all the infos guys. Idiot drivers kill synchros not the SS got it. I'll go ahead and buy the DC shifter and install it. Ill post up pix when im done should be in 1 or 2 days
ill3galdr1v3r
18
10-12-2005 08:44 PM
