92-95 b16 swap
92-95 b16 swap
I am swapping in a b16a2 engine into a 92-95 civic ex. I dont have the ex harness.
I have a jdm b16 (obd1) harness. I want to connect my 0bd2 engine harness into my 0bd1 car. Thanks for the help!
Vernon Slasor
All4Tuners Motorsports!
Vernon Slasor
Re: 92-95 b16 swap (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">won't work the OBD2 harness is one piece, the jdm won't work either its right hand drive</TD></TR></TABLE>
leave the stock civic harness in the car. get yourself a P30 or chipped P28(to run B16). and an OBD1 B series dizzy. plug and play. the CKF will not be used though , which is fine. you dont need the OBD2 harness to do this swap. nor do you want the car to be OBD2 for that matter.
Re: (yeah_its_fast)
dont matter what harness you have , matters what ecu is on the other end of it. OBD1 is better than OBD2 yes. if your car works good itsfast , and you got no codes , and dont plan on going boost , than leave it as it is. dont fix it if it aint broken , lol.
i dont know if its fast.......how would i go about that? j/k
actaully i have seen videos of other obd b16 (jdm) and the vtec snaps hard or harder than mine. i think its because i have a p73 ecu rather than a p30
Re: (yeah_its_fast)
your running a B16A with a P73? lol. no wonder. your vtec prolly aint kicking in till 6000. i think its 6000 for ITR. in order to run a P30 youd need to convert to OBD1. im wondering after thinking for a sec , what ecu did delsol VTEC's run in 96-97? cause other than that , there is no 96-98 VTEC ecu for B16 USDM cars i dont think. goes right from OBD1 , to OBD2B?
well its a dx model then the ecu got pined for the other sensor ie: knock, vtec. i thought the p30 was for 99-00 civic si? i know the p28 is obd1 92-95 the motor is from a 99-00 si i think atleast thats what i thought i picked up from forums
B-serius
07-26-2009 07:05 AM
08zx14
10-23-2008 04:56 PM
danxdan
06-09-2005 04:46 PM
tallblondkid
11-20-2004 02:45 PM
