timing is off hel me!!!!!!!!!!!!!!!!!!
yes, set the motor to #1 TDC on the compression stroke (crankshaft pulley marks should line up with the timing cover mark, loosen tensioner and line up cam marks, tighten tensioner and crank car, reset TDC and check marks again.
Re: (schardbody)
no i just talking about the TDC on the cam gears.
how come when the dots are at the top the lines don't match up
what one should i adjust.
Re: (robert_v)
but then the TDC dots at the top will be off. is that fine?
and when setting the block to TDC is there a difference for compression stroke and exhaust stroke when no timing belt is on?
1) put piston 1 on tdc
2) loosen up your tensioner
3) take off your timing belt
4) adjust your cam gear so they line up, to the head and each other
5) put the timing belt back on
6) tighten your tensioner
timing should be right
tdc is when the single dash on the crank shaft pulley is lined up
Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">i thought on B-series there are some kind of pin hole son the back side of the cams to stop them from moving.
there is..all i did was stuck something in them snuggled and that keep the cams in place..worked fine..dead on..
shark13
19
09-23-2012 11:21 AM
