JDM B18C wiring problem
Heres the problem, i had a local shop install a JDM B18C. So far i noticed that a green sensor thats on a tube running downward behind and below the intake manifold has no sensor on the harness that can possibly reach the green sensor clip. The other thing i found is. along the strip on the harness for the fuel injector sensor clips at the end of the strip their is another sensor hanging and it isnt long enough to clip into anything.
The shop also hooked up a jumper harness and was running on a b16a2 ecu for an automatic tranny to run on for the time being until the B18 ecu arrives.
I dont know what year the motor is. Is their a way to find out?
Does it sound like they installed the wrong harness?
If i install an aftermarket Intake Manifold do i have to alter any sensors?
Sincerely thx, Chris
I know how stupid everything sounds, so im sorry if my newbness annoys you.
Re: (instrument)
sounds like knock sensor to me as well. its the only thing under the drivers side of the intake manifold really. right in between the intake manny and coolant pipe. do you have an engine light?
REeightsix
08-26-2017 11:32 AM
CrazyHB
08-30-2004 12:15 PM
