Need Some Help
Need Some Help
I was wondering if anyone knows whats wrong .i took my cd player out of my car and when i put it back in it doesnt turn on . also my clock resets everytime i turn off my car. i was wondering if anyone knows why this is happening. i checked the fuses and my lighter still works. i have no clue if u do please pm me or post your solutions for me thanx.
Re: Need Some Help (94lshatchback)
sounds like you didn't connect someting back right. The constand + 12 is probably shorted or not connected.
If all looks ok check all of your connections any loose crimps or bad solder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lshatchback »</TD></TR><TR><TD CLASS="quote">I was wondering if anyone knows whats wrong .i took my cd player out of my car and when i put it back in it doesnt turn on . also my clock resets everytime i turn off my car. i was wondering if anyone knows why this is happening. i checked the fuses and my lighter still works. i have no clue if u do please pm me or post your solutions for me thanx.</TD></TR></TABLE>
is the cd player you're putting in an aftermarket or an OEM piece?
if it's aftermarket make sure that the yellow wire off the back is connected to battery voltage....12V+ constant=12V+ regardless of key position
radio wirez...yellow=12V+ constant
red=switched 12v+
if you switch the 2 you tend to lose all your setting like audio adjustments and radio presets and your clock setting
red=switched 12v+
Re: Need Some Help (jz98ctr)
it is aftermarket it was in the before all i did was unhooked it from the wiring harness.i have no power to the radio at all i checked all the wires nothing is loose.
maybe you pinched a wire back there and it's brushing or something. I remember when I installed my stereo there wasn't a ton of space. I know this sounds dumb, maybe you can try just pulling the stereo out and putting it back in, being careful for the wires?
sometimes aftermarket radios have a fuseholder built into their harness...and some have a small fueholder right where the main plug plugs into the back of the unit itself....
if you have an interface harness from metra or scoshe or the like, unplug it and make sure that none of the pins are bent in the end of the plug...
if everything passes the visual test...make sure the wires are not pinched at all and get a multimeter and start testing wires
i would like as much info as you can give...the year and make of the vehicle, the radio manufacturer, model #...
