95 civic w gsr swap having trouble with main relay
i have a 95 civic w a 98 gsr swap my main relay isnt turning on i changed the relay out and still didint work so i changed the distributor fuel pump and gave the car a full tune up and the car wont start unless i jump the relay but for some reason my ecu blew so i had to replace it does anybody have any help thanks pat
and when the car is running its holdin back when the check engine light is on but if i try to peel out the check engine light shuts off and the car got pull
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: 95 civic w gsr swap having trouble with main relay (imports07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imports07 »</TD></TR><TR><TD CLASS="quote">
and when the car is running its holdin back when the check engine light is on but if i try to peel out the check engine light shuts off and the car got pull</TD></TR></TABLE> WTF? did you just do this swap and or has it been running before fine then started having "these" problems?
irev210
06-11-2003 07:00 PM
