piston question
piston question
i have a d seris and i did a mini me swap, now my compression in a 10:1. i wana turbo it but thats a bit high of a compression so i was ether going to swap the pistions or get a thicker head gasket. any ideas personal experinces would be great. thank you ahead of time.
Re: piston question (sal)
about how much will it cost. and do i have to prep the head and block for it. and whie the head is off waht other lil things can i do to increase stablily and a bit of performance
Re: piston question (MugenManR)
Usually around $80-$100. Since the head is off it wont hurt to get it milled to ensure that its perfectly flat to get the best seal. Then again that will bring your compression up slightly so you might not want to.
Re: (MugenManR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR »</TD></TR><TR><TD CLASS="quote">so 10:1 is good to run 6-7lbs of boost. on stock eveything. </TD></TR></TABLE>
you can run ALOT higher boost than that... if it was built..
