is this solder still good???
Re: is this solder still good??? (SLOW_TEAL_HATCH)
as long as it dosn't noticeably move its fine, if your worried you can heat up the iron melt a little bead or solder to it then tap the top of the prong and it will roll down and recoat it. i do this **** all day long at work. but it really should be fine
Re: is this solder still good??? (EG93si)
well i read on this site and my join looks like this
http://www.marklamond.co.uk/te...y.htm
i work for daktronics and i solder probly about an hour a day, ive never even heard of solder doing that, but if you really want to fix it like in that thread, i suggst desoldering them and replacing it all with new solder. as long as theres contact though, i dont know why it wouldn't want to work
did you ever drop the main relay or anything like that? if so, wiggle stuff around and eventually it should get the car to start atleast once, so you can move it to your garage etc. then order a new one from honda for like 40 bucks. if this isnt the problem, we will need more info to help you out
edit: my main relay was damaged and causing my car not to be able to start without any visible marks.
Re: is this solder still good??? (Harryflores)
well it started up a few times today and it completely died and thats it. ive cranked it and nothing. and there is a spark cause i checked that today. so what now
Re: (SLOW_TEAL_HATCH)
looks like a cold solder ring to me. i would deff. resolder it. if its not it wont cost **** to resolder it anyway. and yes a ring like that would make a diff. the piece does not have to wiggle around, the contact at that ring will open and close with temp.l
KickStart2323
06-08-2009 12:19 PM
