CEL code 20 and code 23 after build..
OK engine is rebuilt B16A.
Just breaked-in the motor with this metod: http://www.mototuneusa.com/break_in_secrets.htm
OK engine seems strong after doing that
But just when I was driving back to carage, got CEL 20+23(CEL lighted up when I was accelerating and changed to 2nd gear and popped clutch)
and NOTICE ENGINE DIDN'T shutdown.
So those are Electric load and knock sensor..
When I was connecting that knock sensor plug, I remember that where the plug connects, was very loose...
So I guess it is just that sensor broken? Or the connector?
If I would have knocking, would it be JUST code 23?
Doesn't too lean mixture cause knocking?
I have wideband... how lean mixture causes knocking on fullthrottle?
Thanks!
Modified by ej2civic at 8:48 AM 1/6/2007
Thanks!
Re: CEL code 20 and code 23 after build.. (jfruauff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfruauff »</TD></TR><TR><TD CLASS="quote">I believe all motor full throttle is right at or around 13.0. Not 100% though I am a turbo guy</TD></TR></TABLE>
Thanks for replying, but that isn't what Im asking
Re: CEL code 20 and code 23 after build.. (ej2civic)
did you reset the codes?.. replace the knoch sensor if its broke.. that code mean the knock sensor is not connected or broke.. does not mean your knocking..
Re: CEL code 20 and code 23 after build.. (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">did you reset the codes?.. replace the knoch sensor if its broke.. that code mean the knock sensor is not connected or broke.. does not mean your knocking.. </TD></TR></TABLE>
No I didn't reset
So, think this is broken knock sensor?
One pic of the car
No I didn't reset
One pic of the car
R_Machine
09-10-2005 11:59 PM
