IACV....but want to confirm
I have an irratic idle on my 00' B16b, now from all the searching i have done its either the FIT or the IACV. however i think i read somewhere that at a certain year they did away with the FITv on the engines leaving just the IACV. Is this correct? Or do i have both the FITv and the IACv?
Thanks in advance
Thanks in advance
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: IACV....but want to confirm (B16b-EJ8)
no fitv on 96-up clean the iacv out if it doesn't work then test it to see if it's the iavc itself ..also check for vac leaks
Re: IACV....but want to confirm (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">no fitv on 96-up clean the iacv out if it doesn't work then test it to see if it's the iavc itself ..also check for vac leaks </TD></TR></TABLE>
Any easy way to check for vaccume leaks? I cant imagine there is. On another note thanks for confirming the FITv thing for me.
1 Post
ya just spray brake cleaner on the vac line and anything that is vac related but be very careful don't soak the ****...i hear air intake cleaner is safer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">ya just spray brake cleaner on the vac line and anything that is vac related but be very careful don't soak the ****...i hear air intake cleaner is safer</TD></TR></TABLE>
Would carb cleaner work? and to get this right from what i've read just spray around the connection of the vacume line and then listen for a change or surge in idle correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">yes carb cleaner will work and yes you got it</TD></TR></TABLE>
Thanks i appreciate it
ninjarico
12
02-15-2007 04:26 PM
